Timing affect BLM's
Old Nov 24, 2003 | 08:31 PM
novakm's Avatar
Timing affect BLM's
Just wondering about timing and AFR readings. I know that timing will affect BLMs, but not sure I understand it. It seems that more timing causes BLM's to rise. I don't understand. Seems that with more timing, fuel would be more fully burned, causing BLM's to drop.
Can anyone explain this for me?
Old Nov 24, 2003 | 11:19 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Your guess is right, but if too much timing is added then you'll get incomplete combustion, so therefore O2 is sensed in exhaust and blms think motor is lean.
Old Nov 25, 2003 | 01:00 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
If timing is added and more fuel is burned, then wouldn't that read as lean? That would make the rise in the BLMs make sense.
If I am at 128, and I had more timing, then I am at 134, then I am now running leaner because of more timing.
Old Nov 25, 2003 | 07:13 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Don't get too concerned with timing, just give the motor the timing is runs best with.
Old Nov 25, 2003 | 07:19 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
timing can effect indictate AFR to some degree, for a number of reasons.
Some being, if the timing is too late then the combustion is incomplete, and a false richness can indicated. Too much timing, and the manifold vac can be changed a little, and move the lookup point on the VE table.
BLs, O2 voltages, WB's, are all just indicators. And all can be fooled to some degree. And none taken as an obsolute.
Old Nov 25, 2003 | 09:33 PM
novakm's Avatar
This is exactly the part I do not understand. The sensor is sensing Oxygen. Timing is too late = combustion incomplete = less O2 burned = more O2 in exhaust - shouldn't more O2 in exhaust cause the sensor to read lean? I know it does not, so I 'm missing something somewhere.
Knowing what fools them will help me use (or not use) these tools better
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
tmellott89
Aug 16, 2015 02:58 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
THX181
Aug 6, 2015 10:21 AM
