BLM adjustment with 6E mask
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Im running a 6E mask based bin and was wondering what is the preferred method for adjusting the part throttle fuel delivery to get the BLM close to 128.
Car: An Ol Buick
Engine: Vsick
Re: BLM adjustment with 6E mask
The EZ, way which lots of folks seem to perfer is just juggling the injector constant until things seem about right.
The correct way, is actually using the MAF tables. This accounts for reversion, and gets the calibration dead on, as opposed to about right.
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
So when someone sets their injector constant to a slightly leaner setting than their injectors... IE ... 24lbers set to 25ish...... And they are at 108blm across the board.....
That you should play with the maf tables to accomodate that? Those are some big changes with the tables, and almost seems like lying to the ECM.
__In my case I have a theory that the larger than stock cam doesn't pull as much vacuum as stock, thus raising fuel across the board. That or the HSR regulator isn't in line with a stock one
I do think Grumpy is right, start with your maf tables..... Idle... cruise at what says 20grams/sec, 40grams/sec..... adjust those values to good blm, then use the graphing function to raise the rest in a linear fashion.
I've just started to play with my MAF tables and I have my injector constant set to 36lbers when I've only got 24! 36 got it in the ballpark, but not where I want it. Seems like lying about ones injector constant is worse than lying about the actual incoming air...
BTW I get much more response in BLM from adjusting the MAF tables a little bit, than the injector constant ever did.
Perferred, or correct?.
Tim
It's been a big debate, and one would think if you get the desired results you've done it correctly.
Everyone has their own tools and methods.
understood.... But a couple of years ago I was looked down at for using the maf tables. But if grumpy says it's right ,then I'll be happy cause I always thought it was the ONLY way for 6e blm correction....
Car: check
Engine: check
Transmission: check
Over the years as more is learned new techniques are developed. It is easy to get into trouble when dealing with MAF tables. As long as the person making the changes understands their operation then it works as intended. When that person does not understand their operation, it can get ugly.
Even myself, I only learned how the MAF tables and scalars operate a year or two ago. Up until I went through the code and understood what GM did, I would not have been able to rescale the tables correctly.
RBob.
I am a bit surprised that you would bring this up.
Car: check
Engine: check
Transmission: check
I agree, the maf tables are for fine fuel corrections. A noob could rescale the tables lower and damage something. I would consider the same for the ve tables.
Could you help explain a few things to me?
There are a couple of things to keep in mind when working with the MAF tables. If the last entry of a table needs increasing then the scalar for that table will first need to be changed. Changing a table scalar changes the gms/sec value of every entry in that table. Now every table entry needs to be re-calculated and changed in order to keep the same end value.
Now the last table entry can be updated. Of course this means that the first entry in the next MAF table should be changed. This is because the MAF tables are contiguous.
The flip side to all of this is if you need to change a couple of entries in the middle of a MAF table by a couples of gms/sec, no problem. Make the changes and go. Just have to be careful to not get a false sense of security that the MAF tables are easy to work with.
RBob.
I'm using CATS tuner and where do I find the option for changing the table scalar. I can only find a scale option under the edit menu.
Car: check
Engine: check
Transmission: check
I totally agree. I was hoping you could explain a few thing that I've been wondering. I guess I can just PM you...
RBob.
Car: check
Engine: check
Transmission: check
RBob.
Not sure why a PM is required. I've always answered questions whenever able. . . Tim, if your question isn't DIY PROM related then feel free to PM.
RBob.
RBob.
Also wondering where it's at in tunerpro since I have used that as well as CATS.
By scaler, are you all refering to something separate than the 6 MAF tables available for editing? Or do you mean that when you change a single volt output in the maf table significantly, you need to "scale the table" to keep the graph in a linear fashion?
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
Originally posted by Morley
Block Learn Multiplier
-Corey
Originally posted by Rippin92RS
Can you elaborate? I don't want to hijack this thread but maybe just a brief explanation? Thanks
-Corey
-Corey
As described, the Int reacts to O2 readings and the BLM reacts to the int, trying to keep the A/F carefully balanced.
