Constant charcoal cannister purge?
Old Nov 28, 2003 | 02:41 PM
TORC's Avatar
I'm currently using a charcoal cannister to collect the vent fumes from the gas tank. I have the cannister's purge port hooked up to a constant vacuum source, but the vacuum hose has an inline orifice block in it that has a very small hole in it. The orifice limits the amount of vacuum draw but it is still a constant draw. Is there an inherent problem with this setup? if so, how else would you handle the cannister purge with a '7747 that doesn't support cannister purge?
Old Dec 2, 2003 | 04:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Constant charcoal cannister purge?
I use a ported vacuum source on the TBI. This supplies vacuum only when the throttle blades are above idle.
RBob.
Old Dec 2, 2003 | 05:28 PM
TORC's Avatar
Re: Re: Constant charcoal cannister purge?
RBob.
Thanks Rbob.... do you use an orifice block in the vacuum line or a wide open vacuum line?
Old Dec 2, 2003 | 06:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Re: Re: Constant charcoal cannister purge?
Actually the vehicle I used this method on has an orifice at the fuel tank. Then the line from the cannister to the TBI is open. IIRC the TBI may also have a small orifice at that port, I'd have to check to be sure. I wasn't worried about it as the tank end is restricted.
The cannister that I used only has two ports and no solenoid. It is from/in a '78 vehicle that originally had a carb and is converted to TBI.
RBob.
Old Dec 3, 2003 | 01:21 AM
gregger2k's Avatar
That is the way the TBI trucks are hooked up. You might just get a canister for one of them to hook up.
Greg
BWilcox
Sep 20, 2015 12:19 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
TBRays98
Sep 6, 2015 05:05 PM
