Stock VE table + 406 + 30# SVO's + Stealth Ram = 108 BLM?
Old Dec 2, 2003 | 03:21 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Well, the headers dont glow anymore, so now I'm ready to start making this thing run halfway decent. I've got the stock VE tables in there, with the timing bumped up a little from stock across the board (Base = 8*). The 30# SVO's are running at ~38-39 psi. I'm running 108 at idle right now. Would I be able to compensate by lowering my VE values, or am I going in the wrong direction? Shoulda I try bumping the timing up some more at idle? I havent actually driven the car yet, so I dont know where the BLM is at other loads.
Old Dec 2, 2003 | 03:42 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You need to update your sig. foo ! We'll take your car out this weekend and throw it on Datamaster and run it through VEMaster a few times and see what happens. But like Trax said, even though we get VE close, we still might have "stinky" cams at idle.
Old Dec 2, 2003 | 11:47 PM
OMINOUS_87's Avatar
How much timing are you running at idle?
Old Dec 3, 2003 | 07:40 AM
Scott_92RS's Avatar
Car: 1992 RS
When I reach closed loop, total spark advance is about 16-18*. Idling at 950-100 RPM, MAP of 60(!). I've attached a pic of my main spark table. Think it would be in my best interest to start with the stock timing (I've got my PE spark zeroed out too), then raise the values from there?
Attached Thumbnails Stock VE table + 406 + 30# SVO's + Stealth Ram = 108 BLM?-sparktable.jpg
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
