stock O2
Car: An Ol Buick
Engine: Vsick
Re: stock O2
Originally posted by 11sORbust
Does the ecm use O2 mv for something?
If so/not then why does the aldl spit out O2 mv?
the ecm looks at it only during certain periods. So while to humans that O2 looks to be all over the place the ecm has an agenda as to when to look at it.
It's included so that humans can see it's working somewhat normally.
Car: An Ol Buick
Engine: Vsick
That's what I though, it's for diagnostics. But how does the ecm use mv? It is how the ecm calculates crosscounts? Is that it/all?
There's ALOT of stuff going on in this area.
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Download the ANHT hac and search on "008E". I hope I get this following statement technically correct ...
This address is the RAM address containing the filtered O2 value. It is also the EXACT value that is spit out on the ALDL.
... So, searching the hac for 008E (L008E to be more specific) will yield every place that this value is being used by the code. Note all of the load commands (LDAA, LDAB, and LDX). The mV value located in 008E is being loaded into a section of memory so that the ECM can do work on that value ... analysis ... for a particular purpose. So, YES, it absolutely is being used.
Tim
Tim
Genopsyde
Oct 7, 2015 08:35 PM
