Display fuel flow rate
Car: 85 IROC
Engine: 406
Transmission: A4
Ok in the 1f file in constants there is this setting call Display fuel flow rate mine is set at 3.94 gph. What effect does this setting have I am thinking it has to do with injector size if so would 3.81 be for 19lb injectors and 3.94gph be for 22lb injectors. What would it be for 30lb injectors.THANKS
Car: check
Engine: check
Transmission: check
A display fuel flow is typically used for the dash board MPG display. The ECM collects accumulated PW and accumulated miles and sends this info to the dash.
RBob.
RBob.
Car: 85 IROC
Engine: 406
Transmission: A4
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Originally posted by MR. KIDD
So this would pertain to the Corvette. Why is it ajustable? Thanks for the response.
RBob.
Car: 85 IROC
Engine: 406
Transmission: A4
I guess $1F is Crossfire ECM? I just don't recognize it. It would be adjustable for calibration reasons. Mask's get used in more then one application (typically).To my understanding 1f is for 85 tpi only 870 ecm.THANK YOU FOR YOUR REPLYS
RBob.
RBob.
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
