Codes on ECM sticker...???
Old Dec 6, 2003 | 11:34 AM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
I know what Serv. No. 1228746 is, but there are others that I can't seem to figure out. Here they are:
1.) ATCP (is this a BIN name?)
2.) 86ATCP (another BIN name?)
3.) K193260588 (Serial number?)
4.) 16143651 (another service number maybe?)
5.) Bar code reads: *86ATCPK193260588* (SERIAL NUMBER AND LOADED bin?)
Please help me decipher this stuff.
Thanks in advance...
BTW, I was looking at the PROM and it doesn't look like it wants to come out of the circuit board. There is a large plastic cage surrounding it. This may sound stupid....how the hell does the PROM come out of it?
Old Dec 6, 2003 | 12:53 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Pull up on the plastic "cage", it will come out.
ATCP is the BCC of the BIN. I wish there was a way to decode the BCC to tell what it was from! There used to be, but it was before I got into this stuff.
Old Dec 6, 2003 | 01:43 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Okay...it's out. It looks like you CAN'T put it back in backwards because there are different slots on each side...that's good because I would inevitably put it back in the socket backwards.
Next question, now that I know how to get it out of the socket, do I have to take it out of the plastic housing to erase it and put it in a burner? I'm trying to learn all this before it is time to actually do it so that things will go a lot smoother than if I were going into it all cold.
BTW, I think I may have figured out a way to erase it. I have a UV sanitizer (UltraLum) in the lab where I work. If I took that sticker off of it and put the chip in the sanitizer for 30 minutes or so, would that erase it?
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
eustodp
Sep 20, 2015 05:09 PM
Reese-J
Sep 14, 2015 02:43 PM
RyanJB
Sep 2, 2015 01:27 PM
