Need clarification on Kpa vs RPM tables
Old Dec 31, 2003 | 02:57 PM
87IROC350's Avatar
Engine: 5.7
On the 730 you have the Kpa vs RPM tables.
1. When the KPA is 40 on the lower table does this represent 31-40 or 40-49?
2. When the RPM is 600 does this represent 501-600 or 600-699?
Thanks!
Old Dec 31, 2003 | 03:25 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Re: Need clarification on Kpa vs RPM tables
Thanks!
AFAIK ... and as far as I have witnessed ... 600rpms represents 600rpms. It's not a range. It's simply 600rpms. Now if the current rpm is 550rpms then the ECM interpolates (draws a line) between the 500 and 600rpm values and then determines what to use. As an example ... let's assume that 500rpms and 40kPa has a value of 50. Now let's assume that 600rpms and 40kPa has a value of 60. Well, if you are 550rpms and 40kPa then the ECM will use a value of 55. Clear as mud?
Tim
Old Dec 31, 2003 | 03:47 PM
87IROC350's Avatar
Engine: 5.7
So when evaluating scans I should only be looking at only 600,700,800.....RPM and 30,40,50.....Kpa (matching the tables) to determine changes to be made (and not use the in between values)?
Old Dec 31, 2003 | 06:22 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Initially that's fine.
As you get more seat time doing things, you'll find yourself looking at the fuel table to see what it's doing, also.
Old Dec 31, 2003 | 06:24 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
SO the ECM basically interpolates the in between values, based on the nearest available valuea on the table?
Old Dec 31, 2003 | 06:40 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
No basically involved, it's pure interpolation.
RedLeader289
Sep 23, 2015 06:50 AM
wisemanz28
Sep 20, 2015 01:26 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
Stroopwafel
Sep 11, 2015 06:38 AM
