lm-1
Old Jan 12, 2004 | 11:27 AM
11sORbust's Avatar
lm-1
Where did you route the wire from the (inside)lm-1 to the sensor(outside)?.
Old Jan 17, 2004 | 07:27 AM
chevyhacker's Avatar
Car: 83 Crossfire Z28; 82 Crossfire Corvette; 68 455 Firebird
Just mounted mine yesterday
This is in my 83 camaro - I had the sensor installed right behind the end of my coated ypipe, but before the cat. The cable on the sensor runs toward the front of the car and it wiretied (Loosely!) to the screws on the bottom of the ground effects (used the wireties that have a screw hole, and ground them thinner to fit.
I removed the fender shield that hides the ECM harness and radio antenna entry points. I drilled a new hole (that was less fun than anticipated), ran the round end of the connector to the LM-1 in there.
I removed the front bracket that holds the front corner of the ground effects (right by the tire) to the body. This let me take the end of the sensor wire and pull it up into that little compartment where the new hole is.
I don't believe much water gets into that area, but I know there is lots of air
I forgot to take pics as I went along - let me know if you want some.
Ian
Old Jan 17, 2004 | 12:21 PM
11sORbust's Avatar
I ended up welding the bung at the end of my y-pipe. The wire goes up the outside of the fender and in the window. It's a quick way to check a/f ratio. The sensor can be removed and the bung capped w/o jacking the car up.
Old Jan 17, 2004 | 09:14 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I ran mine up through the shifter boot. The connection is actually in the trans tunnel above the shifter. Unless I start fording streams with it, I don't think its going to get wet. I also use a zip tie to keep it up there.
I mounted my sensor approximately where the AIR tube would be on the cat.
-Jason
6speedIROC
Sep 10, 2013 09:48 PM
Binder
Sep 12, 2007 09:59 PM
Binder
Sep 8, 2007 08:33 PM
getsideways
Apr 24, 2007 12:14 PM
liquidh8
Apr 26, 2006 04:24 PM
