Cold start ?
Car: check
Engine: check
Transmission: check
Originally posted by Grumpy
Does the closed throttle spark, match the main spark table?.
And at 0 and 400 RPM read about 10d, at 100 K/Pa?.
BTW, the truck will take on all comers now <G>
3dF overnight, and 12 hours sitting fired off really quick, idled at about 875 for 2-3 secs, and then to the proper commanded 900 rpm.. EVEN, Doc, was impressed.
Not that I'd ever do this, nope wasn't me.RBob.
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Bruce and Bob, I will try and email u my bin later t-nite when i get home from work and u can comment all u wish :-)
Will check the 100kpa area out when i get home and have my laptop bruce(im at work)
If i barely touch the pedal and crank it over it will start instantly, even at roughly -8deg F this morning.....just frustrating lol
thanks again
Jeremy
thanks again
Jeremy
Car: check
Engine: check
Transmission: check
thanks again
Jeremy
thanks again
Jeremy
Check things like injector PW, IAC steps, SA, a side by side comparsion should reveal something. Maybe AE when you touch the throttle? (slim chance though).
If nothing shows up try more IAC.
RBob.
Car: An Ol Buick
Engine: Vsick
Originally posted by 11sORbust
What does it matter?
Car: An Ol Buick
Engine: Vsick
Originally posted by RBob
You could drive Doc up a wall with a nice cheat: change the code to enable the delta TPS AE while the engine is not running. . . Think of it as a double-pumper and wet the manifold before cranking. . .
RBob.
Bruce,
Gonna try a couple things in A.M.
after that i might give u a call , u gonna be around?
thanks
Jeremy
thanks
Jeremy
If anyone knows where in the code the enrichment routine is (crank with pedal depressed) you could turn it off and then try cranking with the pedal depressed and see if it still starts and stumbles. If it starts easier and doesn't stumble afterwards, then you'd know you need more IAC (more air) during start. If it still stumbles after start then you probably need more fuel during crank.
Originally posted by 87_TA
Could you just not open throttle blades a little more?
Long as you have room with IAC to allow.
Car: An Ol Buick
Engine: Vsick
Car: An Ol Buick
Engine: Vsick
Car: An Ol Buick
Engine: Vsick
Bruce,
thanks
Jeremy
Bruce,
thanks
Jeremy
I was out working on the cold AE correction stuff.
Wow, I'm glad you brought this up. Got me motivated to redo and double check some stuff, the truck is so much nicer now. Instant startups (down to -12dF), and great cold drivibility.
Car: An Ol Buick
Engine: Vsick
Not all are and even the ones that are only go so far.
And you can set it anyway you want, once you know what your doing since it's adjustable,
You would need to open throttle a heck of alot to run out of adjustment.. Even on my car with the healthy cam and 400 cubes I have way more than I will ever need.
On the ones that are not you just elongate the holes.
Car: An Ol Buick
Engine: Vsick
Enlighten me. The slots only allow for so much adjustment, if you open the throttle blades far enough you'll bottom out in the slots...how do you compensate for this? And from what I understand, even the non-adjustable systems can only "zero out" the TPS so far...how do you overcome these limitations?
there are rates of progression for the TPS.
Depending on what code your running they do an auto reset for idle everytime you start the car. But, not all do that. On the ones that don't you have to either adjust the TPS, or adjust the code settings.
For WOT you can set 100% to be lower then 2.8v on some of the codes. Just a matter of reading the hac for what your working on.
I just cracked the blades open then adjust the tps. 87 t/a is right on the money. It would take aprox 25% throttle opening to max the tps slots. Grumpy mention the rate of progression. That is why I prefer an adjustable tps(if it matters).
Ok, so you can reset the values in the code to basically whatever you need to be the min and max values?
So if you are having COLD starting problems you could say set the min TPS value at say 1.0VDC and the max to 3.0VDC....If you do this what happens to the resolution in between? I mean you are going to have less seperation between min and max so won't this affect the throttle response? Make it very touchy?
Just trying to understand the "cause and effect" of tinkering with the code when it was devloped for a specific spread in values.
Car: '01 Lincoln LS - '89 Camaro Z28
Engine: 350 c.i. 1 piece seal truck block
Axle/Gears: stock 2.73 gears stage II
I'm having the same problem with the '89 tpi 350ci that i just bought. I originally guess the IAC valve but that didnt seem to do the trick and i'm gonna try playing with the timing tomorrow.
Is it better just to bring the car to the shop and have them fix it up? Think this could cost too much?
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
