Chip Burning Problems
Old Jan 24, 2004 | 07:32 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I got everything together to burn chips, but now I have a problem. I can't retrieve the bin file from the 16151348 chip that I'm using in my 91 Trans Am. This chip has worked great except for the fact that the injectors are #24 and it's running very rich in the 350. I have a moates adapter, but unless I can get someone to point me to a bin file that I can start with I will have to do some soldering work anyway. I have searched and looked through the bin library, but I haven't found the 16151348 bin yet. Does anyone know where I can get this file or one that will be comparable to it?? This is my final hurdle to get into diy chips. Thanks for the help.
Old Jan 24, 2004 | 08:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
That's a AUJP
If you can't find that on the net email me for a copy.
Old Jan 25, 2004 | 03:16 PM
Axle/Gears: Drums?
I think I'm going to give the bin file in this thread a try as a starting point. I'll have to change the injector constant and see if my cam will affect it, but I believe it should work.
https://www.thirdgen.org/techbb2/sho...highlight=aujp
I've tried to burn this bin into my chip with a willem programmer, but I keep getting a Error Write Sector 0 message. Anyone have any idea what is causing this?
Old Feb 26, 2004 | 04:56 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
I have a Willem 3.1. I can't get it to read or write. The only thing I have accomplished with it is to erase a 27SF512. Anyone else have this happen and know a fix? Should this thing be thrown away and replaced?
Old Feb 28, 2004 | 06:16 AM
IroczInOz's Avatar
You should be able to read the chip as that should not be a problem. What is the problem is programming chips then the programmer has to support it. Because some chips require different voltages.
I used a 20year old erpom programmer to read my data off a 128 chip and it read it fine. But could not program on it.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ambainb
Aug 29, 2015 12:43 AM
NWAsonoma
Aug 18, 2015 05:45 PM
Bryan F
Aug 18, 2015 02:28 PM
Exxon Limited
Aug 9, 2015 08:13 PM
