Timing limitation
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Timing limitation
Was wondering what is causing the timing to be fixed in the 20 to 25 degree range even under load until the coolant is above 114 degrees F. attached is the bin file change the extension from bmp to bin. DataMaster Log is here http://www.moates.net/files/uploads/...to%20house.uni Thanks Craig for the upload space for us to share tuning stuff! 8D 730 ecm
Car: check
Engine: check
Transmission: check
Re: Timing limitation
Code:
L8031: FCB 126 ; 54.5 Deg C, IF COOL >= Disable cold spk, (113F)
Thanks, went back through the hac and found it.
theshackle
Sep 17, 2020 08:26 AM
