TunerPro Free and TunerPro RT v3.06 Now Available
Old Feb 16, 2004 | 11:57 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Word up homies ("hi there my fellow 3rd genners") -
I just uploaded TunerPro and TunerPro RT version 3.06. Lots of good stuff in this release. As always, have fun and be careful! More to come in the next release... stay tuned!
http://tunerpro.markmansur.com/
Whats New in this version?
TunerPro Free
- Added "Difference Tool." With this tool you can quickly and easily view the differences between any loaded bins (either current edit bin and/or any/all of the 4 compare bins). You can limit the search to only defined ECU items, or view all differences within the bin (even those that are undefined in the ECU).
- Added ability to export bin data to a text file (which can then be printed if desired). You can find this option in the file menu. This was suggested by a couple users.
- Added "Splitting" option to Bin Stacker. Now its the Bin Stacker/Splitter. This is EXCELLENT for breaking apart a stacked bin into its individual bins. If you stack a bin using the stacker, save the layout with the stacked bin so you can split it up later if you like.
- Added ability to copy a table to the clipboard for pasting into Excel, and pasting from excel to a table. Right click on the table for the copy/paste menu.
- Made some changes to list interactions (including the item finder, difference tool, summary list, and main lists). Should be invisible to most users, but reduces the number of potential bugs in certain situations.
- Fixed obscure crash caused by item summary list where hiding the main list, showing the summary list, then selecting "new ecu" and then showing the main list would cause a crash.
- Added a white paper to the documentation on "Creating an ECU file from a hack"
TunerPro RT
- Added "disable checksum on bin upload to emulator" feature in preferences. This defaults to uploading 0xAA to offset 0x08 (the mask id). It is recommended that the checksum be disabled for emulation.
- Added read-only support for 2732A, C128, C256, C512 (all AutoProm HW versions) and 27SF512 read/write (write to SF512 for newer AutoProm HW versions only).
- Fixed crash when no ALDL definition is open and any tab other than "setup" is selected in the ALDL comm tool
- Fixed issue with RAM to File. It was basically completely broken. It now works as it is supposed to.
- Fixed issue with simultaneous 160 baud ALDL acquisition and emulation with AutoProm
- Chip I/O - verification makes use of the specified buffer/chip addressing now.
- Chip I/O - save to file makes use of buffer addressing now.
Known Issues
- If datalogging (to file) 160 baud data, Playback rate will not match the recorded sample rate and will be *much* faster.
Old Feb 17, 2004 | 11:42 AM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
What up, G....oops...I meant how's it going Mark...
Thank you sir!!! Excellent!!!
Old Feb 17, 2004 | 12:38 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Awesome work, Mark.
I'll give it a whirl tonight and check out the changes.
Old Feb 17, 2004 | 12:46 PM
Mangus's Avatar
Transmission: T5WC
I should add that the new chips that the AutoProm supports (27XXXXX) are only supported in the latest AutoProm firmware (will be 2.0.A), which is yet to be released (should be in a few days, I think).
Old Feb 17, 2004 | 01:15 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Can anyone point me in the right direction on writing a aldl file for $58? thanks, BW
< edit > Thanks... I hadn't checked all the stuff on your site. FWI your file description says 7748 ECM..
Hehe... things are just getting to sweet.. BW
Old Feb 17, 2004 | 01:16 PM
Mangus's Avatar
Transmission: T5WC
turbo?
explore the site. there's one available for download.
Old Feb 17, 2004 | 06:41 PM
IroczInOz's Avatar
Great work Mangus just tried the copy paste table function and it works perfectly that saves a lof of time.
One question I have though. Is the injector flow rate constant supposed to be showing correct values? The reason why I ask is that it shows 0.0 and in WinBin I get a HEX value to calculate the injector constant.
Just curious.
Old Feb 17, 2004 | 07:17 PM
Mangus's Avatar
Transmission: T5WC
sounds like an issue with the ECU (as is the case 99.9% of the time with issues like these arise). email me the ECU file.
Mark_ZZ3
May 24, 2018 01:02 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
ULTM8Z
Oct 2, 2015 01:25 PM
TexasFormula
Sep 30, 2015 06:36 PM
