What ECU to use 730ECM?
I have been looking at what ECU's to use. There are a few 1227730's ECU out there but all vary on what they display.
I just downloaded the 1227730_8D.ecu off moates.net and the only thing I can't see on that one are the VATS flags MAG VSS flags etc..
I am using an AXXF (92Z28 305TPI A4) chip on my 86 camaro. I just can't seem to find a correct ECU that shows everything. In all the ones I try there are different values displayed.
Like for instance in the 1227730_8d.ecu file and the 730v3_md.ecu file off Mike Davis site the fan temperatures settings are different while using the same BIN!
So what I am basically asking what is the most accurate ECU file availabe for the 730 ECM and has it been checked for accuracy? There are many different ECU's out there it is like a jungle.
Mike
Mike
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Start with the closest applicable factory code to what u r actually running in your car.
Adjust and change what u need to done to achieve better performance and/or driveability for your car, not what others use.
Do a search on individual topics and try and figure out what you7r car likes/wants and work from there
later
Jeremy
later
Jeremy
I think you may have misunderstood my question. I am just wondering what ECU out there is the most accurate to use with TunerPro.
Because of the 3 or 4 I have they all display different values in varies cells.
Car: 69 Camaro
Engine: LS1 converted to LS6
Transmission: 4L70
Axle/Gears: 12bolt 3:42
I am trying to gather support for my Super_8D.ECU. Email me or look at the post. I am trying to make this the defacto standard.
gixxer92
Apr 12, 2022 12:09 AM
KO1
16
Oct 15, 2015 05:00 PM
MikkoV
Sep 9, 2015 04:25 PM
