Ebay ALDL Cables?
Car: 92 GTA
Engine: Yes
Transmission: Busted
Ebay ALDL Cables?
I found this one:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2462778675
And another from mastach.com. A search here reveals that the mastach.com one isn't very good. But what about this other one?
there's also this one:
http://www.customefis.com/cableorder.html
Both cost about the same. Recommendations?
Thanks.
Thanks.
Re: Ebay ALDL Cables?
Thanks.
Thanks.
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
I've been using the Mastach cable since Nov of 03 and have not had any problems yet. Just to let you know.
Talk to Mike at mike@s10wildside.com I have one of his units and am very satisfied. He sells them on ebay from time to time. He also builds custom wiring harnesses. Definatly worth talking to.
Car: 1956 Willys
Engine: 383 TBI
Transmission: SM465
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
lets put it this way:
im selling ALDL cables for $30...+shipping (like a dollar or 3 depending on where you are and if you want insurance) and im making about $25 a cable.
you can realisiticly make one for $5 if you know how to solder.
its a couple resistors, one transistor, a plug, some wires and a way to connect to the ALDL pins.
now you'll have to ignore the tape on the connector... this was my first cable, and i was going to put it inside the serial connector and have just the wire going to pins.....
but then i thought of the box idea and i like it much better.
and heres what it looks like installed on a car.
you just push the box onto the ALDL connector, and the pins slide right in..
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
https://www.thirdgen.org/techbb2/sho...87#post1729187
I just built this one yesterday and it woks fine. I am a clutz at soldering, and still managed to build it.
Just take your time and ask questions.
I bought everything I needed to build it for under 5 bucks.
Z28/ZR1
Oct 23, 2015 01:04 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
