Need help filling out form for custom chip
Old Mar 19, 2004 | 07:20 AM
notaustin83z's Avatar
Car: 87 Trans Am
Engine: 350 Super Ram
Transmission: Level 3 Raptor 700R4
hi
Im in the process of filling out a form for a custom chip by fastchip.com and i need a little help on a couple things...
first, what does FMU mean?
and second, where do i find the four letter prom code.... do i have to go into the ecm, or is there somewhere else to find it?
thanks, nick
Old Mar 19, 2004 | 09:28 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
FMU means "fuel management unit". You run a FMU if you have a supercharger to increase the amount of fuel during boost. This is a bandade, the more correct way is to run an ECU designed for boost.
The 4 letter BCC code is directly on the chip itself. Yes, you have to remove the cover to get to the chip. Look under the blue cover and you will see a silver sticker directly on the chip with the BCC code.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
