OK to run 305 with 350 memcal?
HI,
Just bought a 730 ecm to run the zz430 motor with. I am going to order a memcal from gmparts direct for a 350. Before I start working with the 350, I would like to learn prom burning using the 305 and stock tbi.
1. will the 350 memcal Work OK for the 305 with special buring?
2. Will the 730 ecm run the two barrel TBI OK?, what do I do with the other two injector wires?
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
From what I've been told, The 730 ECM wont work with your TBI setup, things are different not to mention the calibration. The 730 ECM should have 8 inj wires, not 4.
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
