Flash & Burn?
Old Mar 22, 2004 | 10:34 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Flash & Burn?
Does Moate's Flash & Burn chip programmer program 2732a chips, as well as the 29c128's etc... ?
Old Mar 22, 2004 | 08:00 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
it will read 27 series chips but not program them (except the 27SF512, it reads and programs them).
it will read and program 29C128-29F040.
Old Mar 22, 2004 | 09:03 PM
Doward's Avatar
and i can't use a 29c128 in my 2732a equipped 302 MAF ecu, can I?
Old Mar 22, 2004 | 09:12 PM
Mangus's Avatar
Transmission: T5WC
with a Moates G2, you can use a 29C256 or 27SF512. If you order an FnB, order a G2 also. :-D
Old Mar 22, 2004 | 09:31 PM
Doward's Avatar
Hmm... that's not bad... might be quicker/easier to just get a burner that does 2732's as well! Any recommendations?
Old Mar 22, 2004 | 09:37 PM
Mangus's Avatar
Transmission: T5WC
PP2, $179. www.xtronics.com. + UV eraser (around $30)
Or, FnB + G2 for $110. www.moates.net, which gets you away from the UV erase-only 2732As and gets you into the 29C256/27SF512 flash world (which is infinately easier)!
I have both, and both are perfect with excellent support (Moates is a good dude). In a budget situation, the FnB may be a better choice. If you plan on burning chips outside of DIY EFI prom burning, you may want the PP2.
I only burn chips for my ECM, so with the AutoProm/FnB in my posession, I haven't touched my PP2 in about 3 months.
Old Mar 22, 2004 | 09:44 PM
Doward's Avatar
Hey, I sent you a PM! I think I'm sold on the FnB, lol... the G2 will work with my 2.8 MAF 302a, yes? (Should... the 2732 daughtercards all seem the same) so I'd just burn out my bin starting @ address $7000, for the ecm.. ?
Old Mar 22, 2004 | 09:47 PM
Mangus's Avatar
Transmission: T5WC
check with moates to see if it will work with your ECM (he'll probably chime in here at any time).
What ECM are you running?
Old Mar 22, 2004 | 09:50 PM
Doward's Avatar
1277302a, I believe... 86-89 2.8 MAF F Body
Old Mar 22, 2004 | 09:55 PM
Mangus's Avatar
Transmission: T5WC
interesting... new application potentially. again, you'll have to ask moates. you'll probably need to measure your pin spacing to determine which you'll need, and maybe even provide him with a picture of the inside of the ECM.
its likely it can be done though.
Old Mar 22, 2004 | 09:56 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Ya, it should work fine. If you had a 2732A previously, the G2 with a 29C256 or 27SF512 is a drop-in replacement. Takes a little solder work, but not too bad really.
junior419
Apr 7, 2025 11:35 AM
RS Reaper
Oct 17, 2018 07:52 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
lewandom
Oct 1, 2015 08:15 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
