Good Fuel PSI for Tuning
Old Mar 30, 2004 | 12:45 PM
BranZ's Avatar
Car: 1991 Z28
Engine: 5.7
Transmission: A4
I got my act together and ready to start data logging but I was curious on the fuel pressure. This is a 1991 Z28 5.7 Hot Cam with stock ported tpi. I am running 24# from Accel but burned a chip for them. Also, I disabled the EGR. I am currenly runnning 46 psi. Is this too much pressure or not enough. I want to get a good constant before I really start changing things. Any ideas. Thanks, BranZ
Old Mar 30, 2004 | 02:52 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I use 42, just cause it works out to be close to 3 bar. I just run em all the same, so in my lil world, I always know what the baseline is. And the larger the guage face the easier and more accurate it is to use. Might get a Autoclown cheap setup, and then just when you find one, update to a 4" liquid filled one.
Old Mar 30, 2004 | 05:28 PM
BranZ's Avatar
Car: 1991 Z28
Engine: 5.7
Transmission: A4
When you say 3 bar what does that mean. I assume you are referring to the MAP sensor. What is the relation between the two? Any information would be helpful. Thanks, BranZ
Old Mar 30, 2004 | 07:06 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Bar is equal to about 14 PSI.
A 1 bar map is for a N/A application.
A 2 bar map for a boosted application up to about 14 PSI of boost
3 bar map for about 30 PSI of boost.
9192camaro
16
Feb 3, 2019 12:21 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
