Cannot Connect ECM/BIN Dump in Moates 7730
Old Apr 7, 2004 | 03:13 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I am getting a 'cannot connect to car' when doing an ECM/BIN Dump in Moates on a 730 ECM. I am using the default address of 8000 and FFFF and the latest version of the software. The program connects and functions perfectly otherwise. Any clues? Anyone have success? Cable is a homemade two transistor type. Thanks!
Old Apr 9, 2004 | 07:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Moved thread over to DIY PROM, hopefully soemone can help.
RBob.
Old Apr 9, 2004 | 10:45 PM
JMatlock88's Avatar
Car: 1991 Formula
The data is streaming perfectly in all other modes. With Ed Wright chip and stock chip both, the connection times out in ECM dump mode. For an instant, a bunch of digits show up on the screen just before the timeout. Could I have a faulty ground on an ECM ground pin?
Old Apr 13, 2004 | 10:38 PM
IroczInOz's Avatar
You are not alone with your problem I get exactly the same thing. The connection times out. I also get a few digits appear as it is transerfing data but then just loses connection.
Old Apr 13, 2004 | 11:55 PM
JMatlock88's Avatar
Car: 1991 Formula
Great!...err...not great
Have you tried older versions of Moates software? I plan to try that next time I can get to it... Mind tryin' that idea too?
Old Apr 14, 2004 | 08:21 PM
IroczInOz's Avatar
Yeah I have tried all his versions without luck. I know his frist version did not work, then I tried the second version with any luck. Not sure what version he is on now but I have not tried it.
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
