i have no parillel port
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
what am i to do about a eprom programmer is there away to use usb
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
If you haven't already bought a programmer, the only USB programmer I know of is from Moates.
If you have and it uses a parallel port, then you have no options for converting to USB.
Engine: l98 and lo5
i have not bought a programer yet i was looking at the pocket programer due to the fact it is tried and true. i have a lap top that has a serial port and usb i was hoping that there was a way to add on to the laptop a perillel port to my dell d400
Transmission: T5WC
The moates programmer supports all chips you'd ever need for DIY-PROM and is only $75.
If you want a PP2, you'll also need to buy a parallel port interface PCI card in order to use it.
Engine: l98 and lo5
dose the moates come with the software to use it or is there a program out that that he likes you to use with it
Transmission: T5WC
www.moates.net
yes, there is standalone software (that I wrote). TunerPro is also fully compatible. =)
