need more stable datalogging with 8.52 moatesware
Old Apr 8, 2004 | 03:04 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I'd like to get anyone elses suggestions on more stable datalogging with Mr. Moates' 8.52 software. I've got the laptop hooked up to a '87 Z(Iroc) '165 via the Max232 homebuilt cable, works good, for sure, all connections are secure and reliable the chip is powered from a regulated 12v source(down to 5V per schematic). Also, powering the laptop from an inverter from 12V.
Seems that the program will hang when I try and start logging info, sometimes its seconds, sometimes its minutes.
Now, I know I've seen mention of this multiple times, but really haven't seen any resolve. What is everyone else doing to improve their scanning abilities? Using other software on these danged '165's?
Does anyone know for sure the problems? ground loops? intermittent data? Interaction from the inverter and laptop? Ignition interference?
thanks in advance.......
Old Apr 8, 2004 | 04:43 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
This is an issue with the ECM itself. Even my AutoXRay scanner locks up with the 165.
Generally you can alter the baud rate to get a more stable connection. Mine seems to prefer 8200.
Old Apr 8, 2004 | 06:44 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
mine is stable as all hell, even with my amateur soldering job...I log up to hour of driving on a regular basis.
BTW I use the 2 transistor cable with Moates 8.52 on my 89 GTA 165 ECM
Old Apr 8, 2004 | 09:46 PM
jwscab's Avatar
Engine: Many
Thanks for the replies. As to the problem in the ecm, is it something related to an inaccurate clock rate, or something like that? Any info on the root cause of why it hangs, in any better detail?
I'll try messing with the baud rate though, thanks for that tip.
short of that, what does anyone else running a '165 have good luck running with?
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
BWilcox
Sep 20, 2015 12:19 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
