AutoProm with Windows 98
Old Apr 18, 2004 | 10:55 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Wanted to verify correct setting for my laptop (Com port 1)
Using PCM 16147060, $85, AT29C256, TunerCat
Port Settings:
Bits per second: 115200
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Hardware
Drive File Details:
C:\Windows\System\Serial.VXD currently selected
C:\Windows\System\VMM32.VXD (vcomm.uxd)
C:\Windows\System\SerialUI.DLL
Resources:
Automatic Settings Currently selected
Input/Output Range 03F8-03FF
Interrupt Request 04
Look OK?
Old Apr 18, 2004 | 03:19 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
It shouldn't need to be that complex.
Just make sure you've got the correct port selected in your software (for the serial AutoProm, on most systems this is COM1, on some it may be COM2).
Flow control should be set to none (looks like its currently set to hardware). The AutoProm does not use flow control (nor does the Romulator).
The software will set the port up in terms of baud and whatnot.
You don't want to mess with the address/interrupt settings of the port. Leave those be.
Old Apr 18, 2004 | 03:31 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I agree
I already had Com Port 1 selected.
Would the flow control set to hardware cause issues with burning chips?
Thanks for the help!
Old Apr 18, 2004 | 04:08 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I'd go ahead and set it to 'No flow control'.
Also, go into your advanced button under the Virtual COM Port and make sure your Latency is set to '1'.
Old Apr 18, 2004 | 04:23 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I had previously disabled this port. I could not find a setting for latency.
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
tmellott89
Oct 14, 2015 02:06 PM
kkirch15
Sep 30, 2015 04:44 PM
