Unplugging O2 sensor
Old Apr 19, 2004 | 10:16 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
If I burn a chip to keep me in open loop and I unplug the stock O2 sensor to replace it with my wide band, will it throw a code? Id just go check myself, but the car is in storage till Fri
Thanks for any help!
Old Apr 20, 2004 | 03:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Here you go chuck. I moved it for you.
Old Apr 20, 2004 | 03:21 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
I'm not a TBI guy, but I'd think that when you burn the open loop chip, just disable the O2 sensor diagnostic flags (DTCs 13, 44, & 45, IIRC) and you should be good to go.
(works for other ECMs)
Old Apr 20, 2004 | 05:39 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You want to set the Closed Loop, Coolant temp enable to the max., and then disable the flags for codes 13, 44, 45.
I think there was some mention in other threads about the some items being related to closed loop.
Old Apr 20, 2004 | 08:38 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Great as always, thanks guys.
db057
Jan 10, 2020 08:55 PM
L98GTA87
Oct 19, 2015 10:43 PM
earlpote
Sep 12, 2015 11:55 AM
Logan Bryant
Aug 27, 2015 11:52 AM
perZ
Aug 21, 2015 05:51 PM
