swaping to speed density in my 91
Car: 91 formula
Transmission: t5
i started off with tbi in my bird, and then got a 87 tpi complete with ecm
but now i wnat to put speed density on it
can i use my comptuer from the 91 ? i dont know what one it is but i took a pic of the sticker on it, i wuld just need to get a chip burned right ?
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
No, you'll need a 1227730 ECM (or equivalent, P/N 16196344 or 16198262 are essentially the same thing).
A great writeup on how to convert your '87 TPI rig to the '730 can be found at:
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Car: check
Engine: check
Transmission: check
Originally posted by white91formula
will a 91 or 92 6cyl car have the same computer ?
RBob.
Also, if you're at the junkyard trying to find a '730, note that it doesn't need to be from an F-body. '730 ECMs are very common in late '80s/early 90's 2.8L and 3.1L FWD cars.
Elephantismo
Feb 13, 2019 12:51 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
