How do you change trouble code parameters?
Old May 3, 2004 | 04:14 PM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
I am running the following:
-3.4L bored w/ solid cam
-modified TPI setup w/ dual 48mm TB
-24 lbs injectors
I am throwing a code 34 which is too high of a signal from the MAF since I have a larger bore, intake, etc. I have been told that I can change the parameters of the trouble code. I am using a PP2 and the tunercat software. I can't find the parameters on the eprom anywhere. Does anyone know where these parameters are stored?
I should add that I am using a 302 w/ $3a eprom.
Thanks,
Jim
Old May 4, 2004 | 06:55 AM
JohnL's Avatar
I don't have a copy of a $3A ECU file, but in the ECU's I'm familiar with, you can disable the trouble code by unchecking the trouble code's box in the appropriate Malfunction Word (these list in the "Flags" section of Tunerpro).
John
Old May 4, 2004 | 07:43 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I haven't seen anything public domained on that Mask.
Your best bet would be writting to Tunercat, and explaining what you have going on, and asking him to add the items into a revised .tdf file.
1992Vortec
Aug 31, 2015 08:05 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
