Confused with Injector Size.
Old May 11, 2004 | 08:44 AM
Cobra289's Avatar
Car: Cobra Kit Car
Engine: 350 HSR
Transmission: TKO 600
Axle/Gears: 3.31
I was checking my original $32b BIN dump (ABUT8562) from an 87-305 A/T Cal. Because I have changed to the $6e APYS3509
Looking to the “Single Fire FI Size @ 40 psig” at the ABUT it gives the size of 20.82Lbs/Hr.
Looking at the APYS and I see the size of 19.48Lbs/Hr. also the ANZA is giving this size.
I though that every TPI 305 got the size of 19.48Lbs/Hr.
Is this some special set-up?
Regards,
Cobra289
Old May 12, 2004 | 04:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Confused with Injector Size.
Regards,
Cobra289
My understanding is that the early TPI setups ran a larger injector at a lower fuel pressure. I don't recall what years or what models (Y/F). This cal may be for one that did just this.
RBob.
Old May 12, 2004 | 04:33 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Believe 85 TPI wa sthe only with FP at 35. In 86 factpry went to 43 line off and actually had a bulletin (maybe recall) on earlier cars for a prom and a new regulator
later
JEremy
Old May 12, 2004 | 05:08 PM
Cobra289's Avatar
Car: Cobra Kit Car
Engine: 350 HSR
Axle/Gears: 3.31
OK,
We are talking here about a Camaro late 87 from California.
Is the 32B ECU correct?
“Single Fire FI Size @ 40 psig” the 40 psig is the fuel rail pressure and not the injector test pressure (43.5113 = 3 brag)?
Therefore, the 19.48 lbs/hr. at 40 psig is equivalent to 20.3 lbs/hr. at 43.5 psig.
That means that for an 89 F body you need to buy a 21 lbs/hr (Advertised) and if you use a different value, let’s say 24lbs/hr you need to adjust these value in the bin file.
Regards,
Cobra289
92-Formula
Dec 12, 2015 10:34 PM
Jorlain
Oct 8, 2015 01:57 AM
bubbaz28
Sep 18, 2015 02:09 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
