where to start
Old May 18, 2004 | 08:56 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
where to start
ok i would like to tune my lo5. a guy i know just opend a dyno shop so now i have a dyno that i can use. i was thinking of tuning with the fp to get peak hp then fine tuning the eprom. or should i programe my eprome first. i just dont want to get on the dyno and find out that i have to boost up or drop my fp and screw up my tune. how would you guys sugest i takle this thing
Old May 18, 2004 | 09:05 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
I think I would do the FP first. But thats just me.
Old May 18, 2004 | 10:16 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: where to start
It's a careful blend of working back and forth.
With properly sized components you shouldn't have to dink with FP to tune the motor.
A read thur the Final Answers should shed some light on things.
Old May 18, 2004 | 10:28 PM
c4boom's Avatar
Engine: l98 and lo5
my setup is
a comp cams extreme energy cam grind # xe249h-12 this cam has 206 212 duration at .05 lift (I/E) and .434 and .444 inches (I/E) of lift. i also have edelbrock TES headers, a holey projection intake, holley tbi unit part# 502-6 with the 65 pph injectors and 3 " exhaust to the muffler (flow master 50 series) and then duel 2 1/2 out the back and last and least the crappy stock swirl port heads
i just want to make sure that i do not max out the injectors due to the fuel pressuer being to low at the top end. i have it set to 15 psi right now. i would hate to tune the lower end and then find out that the injectors do not flow enough to suport the motor at the top at there curent setting
Old May 19, 2004 | 01:31 PM
Ronny's Avatar
some thing tells me the underlying VE tables will have an effect on the final commanded A/F ratio in PE or WOT? i set my FP to 12 lbs and worked on the fuel tables day one of tune. after getting them corrected(reasonably close) BLMs in a few sessions(800 to 3200 rpms) closed loop. i headed to dyno. i had "commanded" the A/F to 12/1. WBO2 showed 11.9/1 and 12.1/1. maybe dumb luck. i was concerned i would go to 16/1 and engine would melt on dyno. dyno operator suggested i stand back as it probably will send parts of engine out the door and through the roof. it did not. reset commanded to 12.5/1 in PE. i felt warm and fuzzy.
Old May 19, 2004 | 07:21 PM
c4boom's Avatar
Engine: l98 and lo5
what was your max hp out put on the dyno
Old May 20, 2004 | 10:17 AM
Ronny's Avatar
222HP rear wheel. 5100 rpms. 12/1 A/F. 85 deg F temps. conservative timing.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
