Learning Source code links
Old May 21, 2004 | 01:04 AM
Z69's Avatar
Z69
The stickie with learning source code in it had some links posted by Glenn. They are broken.
I PM him, but no response.
Anybody have more links?
I have the 68hc pdf. Nice and long. And dry..
Old May 21, 2004 | 07:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Learning Source code links
Can you post a link or name of the stickie in particular?
Thanks,
BobR.
Old May 21, 2004 | 11:35 PM
Z69's Avatar
Z69
One link is for xx.owlnet.xx, the other was to a thread that had all of the links Glenn wanted to post.
Stickie
Old May 24, 2004 | 03:32 PM
Z69's Avatar
Z69
ttt
Old May 24, 2004 | 09:40 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Stickie
Did a google on that one and came up with this:
Link
After finding the unbroken link, I see why it got turned into "****", it was censored. R1ce....
Try google. Enter your search a few different ways. That's how I came across most of the stuff I had found, but I just grabbed stuff and didn't bookmark stuff (I know, I should have!!!)
Old May 24, 2004 | 10:04 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
found some stuff
did a couple of searches and found this link.
http://www.mcumaster.com/hc11/index.html
Lots of good reading!
You didn't need the sleep anyway
Old May 25, 2004 | 03:16 AM
Z69's Avatar
Z69
Thanks JP (Judd) and er ...JP.
Yeah I do need the sleep. Now I'm being an idot. I was up till 4am the other night researching my next project.
Now, HTH do you get that owlnet link to work?
edit: Duh.. Rxxx
Too little sleep
Getting lazy too, starting to hate searches. Keep getting side tracked.
Old May 25, 2004 | 04:55 PM
JP86SS's Avatar
no idea, still searching
couldn't make it work so I searched for the doc that the link points to and came up with the link I posted.
There is ALOT of stuff out there on the subject.
One thing the link I posted did show me that was not evident in the other readings is that the OPCode changes based on what type of addressing is used.
That opened my eyes to see some new things that I couldn't follow before.
Good luck, we'll be learning this stuff together.
One quick question for anyone,
What is the meaning of FCB at the start of the memory? (addressing the I/O to memory locations or defining variable locations)
And the difference between FCB and FDB?
Thanks,
JP
Old May 25, 2004 | 06:01 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: no idea, still searching
Originally posted by JP86SS
. . .One quick question for anyone,
Thanks,
JP
FCB forms a single byte of data to memory.
FDB forms two bytes (Double) of data to memeory.
RBob.
Jorlain
Oct 8, 2015 01:57 AM
gta90
Sep 15, 2015 04:00 PM
angel2794
Sep 8, 2015 06:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
RyanJB
Sep 2, 2015 01:27 PM
