MAF Relay Cable Part #'s
Old May 22, 2004 | 10:01 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Does anyone have the part numbers for the cables that go to the MAF burnoff and power relays?
Old May 22, 2004 | 10:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To my knowledge, these cables are a part of the engine wiring harness and are not sold seperately. Are you by any chance talking about the connectors on the cables?
Old May 23, 2004 | 03:27 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I read in another post that when you get the connectors it comes as a pigtail. I believe it was Morley that posted that.
Old May 23, 2004 | 06:20 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Well You can get them it just depends on what type of relay you are using.
The Relay Harness plugs for the one on the left can be ordered thru a GM dealer under P/N 12101922
The Relay Harness plugs for the one on the Right can be ordered through
NapaOnline at part # ECHEC191
Or through www.rockauto.com using part # PT1115 or #15306002 If using these make sure that they are a 5 wire connector.
Old May 23, 2004 | 07:07 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
The relays that I am using match the one on the right. So you only get the plugs? There are no wires attached to them? I am doing the '870-'165 conversion. I guess I can just use the wires from the MAS Module. Thanks.
Old May 23, 2004 | 08:30 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
The Plugs Have about 6" - 8" of wire attached.
also with those Relays the wiring is a little different than in the 870-165 Swap on mike davis site.
I have the proper way to wire the Relays on the Right(Thanks to Morley) Read the thread here 'Did I get the right parts(870-165ecm) and in the last Couple of pages Morley And I talk about using the 1989 Relays which are the ones on the right. The Ones on the left are what mike davis used in his tech article on how to swap a 870 out for a 165. The pin configuration is a little different between the relays.
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
