Did I get the right parts(870-165ecm)
Old May 13, 2004 | 12:03 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
Went to a junk yard and got these for $20, didn't think to check the vin 1st ..oh well, it was only $20.
I tried to find the tarelay picture so i could compare, but couldn't find it.
Can anyone identify these in a jiffy? I'm not so much interested in the relays b/c i can buy them new if needs be, but rather, i want to make sure i have the correct harness.
Old May 13, 2004 | 01:19 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Which ecm do you want to use?.
85-89 has two ecm connectors.
90-92 is 3.
I see a MAP sensor, so it should have 3 ecm connectors.
Being's a 730 application, (3 connector), you should have just 8 injector connectors. 85-88 had 9.
I can't see enough detail to really tell you if you got the right one or not.
For $20, I'll take one
Old May 13, 2004 | 01:32 PM
Cobra289's Avatar
Car: Cobra Kit Car
Engine: 350 HSR
Transmission: TKO 600
Axle/Gears: 3.31
I think that you miss a lot to make a 165 TPI, if that is the goal.
I don't know for a TBI but I have put a readable picture on my site for the big connector on the left side.
I use the book of a 1987 Camaro.
To download from the site just hit the:
http://www.donostia.demon.nl/Image002.jpg
it is 1.5 Mb.
A smaller version you can see here.
I hope that this will help you.
Regards,
Cobra289
Old May 13, 2004 | 06:49 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
hmm...i'll try to get better pics.
if it's the wrong harness, i'll straight up trade you for the correct one, grumpy . i'm trying to go from 870 to 165...maybe i could go 870 to 730? i imagine from pos maf to SD would be a big jump, and means i need more parts. i already have the 165 ecm too
and cobra...you could tell me that pic is used to make spaceships, and i'd believe you.
Old May 13, 2004 | 07:08 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
If you've already got an '870 car, you shouldn't need a whole new harness, just a few changes to the one you have.
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
The '870 to '165 conversion is more involved than the 165 to 730 conversion. Once you've updated your '870 harness to '165 configuration, further modifying it to SD is a piece of cake.
Also, don't worry about the C100 connector -- starting with an F-body basically takes care of that for you. Even when I converted my carbureted '83 LG4 to TPI, I didn't have to change anything in C100. IIRC there's like one wire different between TPI and some of the TBI cars, but that's about it.
Old May 13, 2004 | 10:40 PM
SBNova's Avatar
If your looking for the harness that the Davis site says is "required", you dont need it. When I swapped my 870 for 165 I bought the relay plugs from NAPA for like $6 each. I bought new relays at Advance Auto parts (it was difficult to find them- actually look them up). The NAPA plugs have plenty of length, and when I unplugged my factory 870 burnoff- there was enough wire between the two of them to do the job. I mounted my new relays right where my 870 burnoff went. This was on my 85 Vette, a Camaro Firebird may be a little different- I dont know. Other than finding the right relays it was a piece of cake.
Old May 14, 2004 | 11:48 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
so then all i need is the relays, and not the harness?
sbnova...can i im/email you about this? it's hard to get ahold of people who've actually done this.
my email is n8man1068@yahoo.com, aol/aim is N8MAN1068.
thanks.
Old May 15, 2004 | 06:29 PM
edfirebird's Avatar
Hi. Nice combo probably like mine ;just lacking that little bit from Good to Smoking Gobs of Power( I get high from laying rubber/ Real Street Performance) . You need the ECM pinouts for the diffrent configurations of the ECM Plugs. Put them together and figure out which pins are moved and where;I marked up the ECM pinout diagram with my changes and color codes too allow future refrence. In addition and sensors which have signal inputs into the ECM will require a connection to the 5 volt and signal grounds into/or at the ECM. I found to switch my car between a 730- $58, 165 - $6E , and $5D - 808 code and pinouts can be completed with just unplugging adapters. You might want to consider the 7808 computer w $5D map or $12 their a bit diffrent but have useable features available like a BPW closed loop / open loop Aussie setup it has even less wires and has better resolution. If you are considering the 7730 the 808 is fewer connections.
Do a search on the diffrent keywords and youll find some useful info.
Ed
Old May 15, 2004 | 07:36 PM
Morley's Avatar
thanks.
You'll need 2 relays and plugs/pigtails for both. As mentioned, when you buy the relay socket you get almost a foot of pigtail too, more than enough to hook them up and put the relays on the bracket the MAS module was on. Did this same swap about 2 years ago (870-165) and it took 3-4 hours, simple swap.
Old May 15, 2004 | 07:51 PM
edfirebird's Avatar
Oh yeah the only obvious disadvantage is the 160 baud vs 8192 in a 7730 MAP / 7165 - MAF.
Ed
Grumpys says that you should always datalog and review while keep notes.Thus making the 160 baud in the 808 code just fine for simplicity and getting data.
Old May 16, 2004 | 12:04 AM
Morley's Avatar
Ed
The 165 is 8192 Baud...the 870 was 160 Baud (as were the TBI ECM's)
Old May 16, 2004 | 05:38 PM
Dave_Jones's Avatar
160 baud is better than nothing, but it's not "just fine" IMHO.
Especially once you start trying to tune AE and transitional stuff. A lot can happen, in between frames at 160.
Given the choice, 8192 is the way to go, if you're going to depend on the ALDL for datalogging.
Old May 16, 2004 | 08:08 PM
edfirebird's Avatar
I agree. I'm all about faster baud rates. The 808 code didnt support the high speed uart in our 1227165. Even though the hardware does. If he allready had a 7165 ecm I was just suggesting an eaiser hook up. Hope fully some one find's a way to patch the serial code from like a 6E or 32B to the 5D(808 Aussie). The aussies had later code w/ better resolution for tables and 8192 there's just limited ECM/ DEFs avail for us noobies.
Ed
Old May 17, 2004 | 11:31 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
man, ya'll are speaking greek....
so when i get the relay's and matching pigtails (is there another term for this, so i dont sound like a moron at autozone asking for these?), are the pigtails color coded? while i'm pretty new to this, i can still put 2 diagrams together, look at the pretty colors and see where they need to go.
if all this extra wiring isn't necesarry, someone should tell that guy so they can update the tech article so people like me don't spend a long time searching for an uncut harness.
thanks again:hail:
Old May 17, 2004 | 12:17 PM
Morley's Avatar
thanks again:hail:
The relay socket wiring is colored but doesn't correspond to the GM harness colors. The relays have their internal wiring diagram printed on the outside shell so it is just a matter of matching up the functions to wire it in. Check the wiring diagram on the relay against the one for the ECM swap so you have the power & grnd in the right place as well as "function" wires (ie MAF power & Burn off) If you are in doubt of which is which on the pigtails, hook an ohm meter to the 2 that "should" connect once the relay is closed and hook a 12V power source to the ones that "should" actuate the relay and see if it is right.
Old May 17, 2004 | 02:54 PM
SBNova's Avatar
My Napa pigtails had all white wires.
Did you get my email with the link????
Good luck.
Old May 17, 2004 | 04:24 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
yes i did sbnova, and thanks.
i replied to the email, but figured i'd also put it in here in case anyone else can get usefull info from this.
you stated that i don't need the old harness, but the links also refer to pin swapping. could i not just splice the pigtail leads into the harness? (now that i think about it, probably not). or maybe solder the pins directly to the leads, and plug it into the correct harness socket?
Old May 17, 2004 | 06:15 PM
edfirebird's Avatar
The old harness is usable if you take both ECM pinouts and schematics for the car. Then determine which wires need to be moved in the ECM pin header(pin swaping). Any wires which need to be connected to a new relay can be wired in into the existing harness. Any relays added If you removed one and have the schematic you would know which wire went to what( batt, pin at ecm, fuse box .... Then make your connections using the existing wires or your new 2 you harness( off the donor car). Just keep the color code true to OEM specs and you can diag your car if necessary in the future. The existing harness might have the pins in the right spot for some things! I habvent seen both ecm 870 and 165 side by side but It is possible.
This keeps the original wiring intact as much as possible to avoid a lot of splicing which can all bite you in the butt later. (Solder all you connects then use really good tape strech while wrapping and or heatshrink tube.
The davis site has a pin swapping guide bewteen the pinout for a 870 and 165.
Ed
Old May 17, 2004 | 06:19 PM
edfirebird's Avatar
Go to Gm-ECM and dowload the wiring schematics for a 165 and 870 then print them and see which circuits connect to where. The donor harness or new relay pigtails allow connections for the different / new relays.
Old May 17, 2004 | 11:08 PM
Morley's Avatar
Go here http://www.eecis.udel.edu/~davis/z28/ecm_swap/ and have a look.
The "donor" harness he talks about is just for the relays, you don't need it. The relay sockets you buy have pigtails that are all you need and you'll be mounting the relays on the MAS module's bracket on the ECM, not on the firewall in the engine compartment.
Just take your time and mark each wire you remove during the repin.
What I did was make a tag from masking tape for each wire that gets moved. on the tag I wrote the position it came from and the position it was going to (ie A11 to C12), that way I could go back and double check all of my repins. For the splicing I didn't use the crimp on splices he shows, instead I carefully stripped the insulation in a 1/4" long area and solidered the wire to it and taped the splice good.
Old May 18, 2004 | 12:11 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok Morley Shed some light on something for me
I don't understand the splicing Part of it.
In the orginal 870 Wiring there are already splices why don't you just Repinn the splice.
Example
In the ECM Wiring on the 870 The orginal Injector (1,3,5,7) Consists of D14 and D16 are Spliced
Then Below you will See where D14 is repinned to D15 so now you have D15 and D16 so in the Splicing it says splice D15 & D16 But that would be splicing both injector banks togeather.
After the repinning what should the splicing consist of.
(Old D14) Which Is (New D15) is Spliced to ? To complete the NEW (INJ 1,3,5,7)
Same With the (Old D15) which is repinned to New (D16) Is Spliced to ? to complete the NEW (INJ 2,4,6,8)
Code:
Repinning
870' 165'
A11 (MAT)				C12 (MAT)
D2  (Fan Ctrl)				C1  (Fan Ctrl)
D8  (EGR Diag)				C15 (EGR Diag)
B4  (EST Ctrl)				D4  (EST Ctrl)
D13 (TPS Gnd)				D2  (TPS/CTS/MAT Gnd) ^*
C9  (Fan Reqst)				D11 (A/C Pres. Fan Reqst) %*%
B11 (MAF)				B12 (MAF)
D12 (MAT/MAF Analog Gnd)		A11 (MAF Analog Gnd) ^*
D15 (Inj 2,4,6,8 "B") (1of2)		D16 (Inj 2,4,6,8 "B") ^*
D14 (Inj 1,3,5,7 "A") (1of2)		D15 (Inj 1,3,5,7 "B") ^*
Splicing
C15 splice D15 (Inj 2,4,6,8 "B")(2of2)	D16 (Inj 2,4,6,8 "B") (new D16, old D15)
D16 splice D14 (Inj 1,3,5,7 "A")(2of2)	D15 (Inj 1,3,5,7 "B") (new D15, old D14)
Old May 18, 2004 | 12:48 AM
Morley's Avatar
Splicing
Splice C 14 & D 15 together and put in D16 spot.
Splice D14 & D14 together and put in D15 spot
Maf Burnoff relay - pin A MAS connector pin D
and MAF Pwr relay - pin D
Take the wires from pin A on burnoff relay and power relay, solider them together and splice into Pin D on the MAS connector.
Maf Burnoff relay - pin C B1 (12V and oil sw override)
and MAF Burnoff relay - pin E
and MAF Pwr relay - pin E
Burn off relay pins C & E and power realy pin E get spliced together and solidered to an ECM pin you will end up cutting off for splices and put in spot B1
MAF Pwr relay - pin A MAS connector pin F
MAF power realy pin A spliced to MAS connector pin F
MAF Pwr relay - pin B D3 (Ground)
MAF power relay pin B spliced to D3 on the ECM
MAF Pwr relay - pin C B2 (FP signal)
MAF power relay pin C spliced to pin B2 on the ECM
Old May 18, 2004 | 12:51 AM
Morley's Avatar
Example
I think what is getting you here was that the 870 had redundant pinouts for both banks of injectors and the 165 doesn't. All you are doing with the splicing is marrying up the even and odd injectors into one connection and putting them in the proper place for the 165's operation.
Old May 18, 2004 | 02:31 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Does anyone have the part numbers for the relay socket that have the pigtails? I have the relays but I need the plugs and harness that go to them.
Old May 18, 2004 | 03:28 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
so the wires are spliced togeather and go into on spot. Hmmm
Now it makes alot more sense
so it would go like this:
So the old D14 & D16 Splice into One connection and Hook into the New D15 For the 165' (Inj 1,3,5,7 )
And the Old C15 & D15 Splice into One connection and hook into the New D16 For the 165' (Inj 2,4,6,8 )
In respect sorta like this Morley?
Well If My thinking is now correct I am not too far off from My Swap for I have a 165 ECM and also the Lisle Terminal Tool, and all the relays and Factory Relay harness, Now If I only had a V8 5.0 Memcal. :hail:
Old May 18, 2004 | 05:44 PM
Morley's Avatar
Now you've got it, MTPFI-MAF. The memcal is going to be hard to get on the cheap. You may want to just break down and buy a new one from GM for about $60.
Old May 18, 2004 | 06:01 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Well Since I run a T-5 with a 305 for now I am going to buy one with the ANZA Prom Memcal. Magnus (tunerPro Creator)use this bin so I will have a little upgrade support. Rockauto.com has it for $48.00 but I find out today that my Lisile Termanl tool is on backOrder and I need one of these Termanl tools too repinn the harness and I don't want to use a Paper Clip. What are my other options to buy a C3 Terminal Removal Tool.
and BTW Morley Thank You For Clearing This Up. You Rock.
If ya ever need some fiberglass Shifter Plate or Dash Plate made look me up.
Old May 18, 2004 | 09:03 PM
Morley's Avatar
A small jewler's screwdriver is all you need to unlock the pins in the harness, it won't mess up anything either.
Old May 18, 2004 | 09:25 PM
Dave_Jones's Avatar
Some Pep Boys and NAPA stores sell a set of "terminal picks", for about $10 or so.
Incidentally, when you look at one of those sets, the correct "pick" for the ECM terminals actually is a very small screwdriver
Old May 19, 2004 | 05:35 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok I am going to get a jewler's screwdriver but here is what I noticed last night while looking at my Relays that came form a 89+
in mike davis web site it says Pin B on the MAF BurnOff Relay and MAF Power Relay, well the relay I have is like the one in the picture and there is no pin B only A, C, D, E, F So Morley What revisions need to be made to make these work Correctly
Diagram also below for camparison.
Code:
Splicing
New hookup
		D12 goes to Maf Burnoff relay - pin B
Old May 19, 2004 | 10:55 PM
Morley's Avatar
Ok, on the MR 44 relay, pins D & F correlate to B & C on the wiring diagram's relay and pins A & E will be the same (this is for the burnoff relay and if it is used for the power relay)
Old May 22, 2004 | 06:38 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
So On a MR44 Relay I would Need to make the changes below Correct Morley.
Code:
Splicing
Maf Burnoff relay -  pin C  or with a MR44Relay Pin-F		B1 (12V and oil sw override)
MAF Pwr relay - pin B or with a MR44 Relay Pin- D			D3 (Ground)
MAF Pwr relay - pin C  or with a MR44Relay Pin - F			B2 (FP signal)
New hookup
		D12 goes to Maf Burnoff relay - pin B or with a MR44 Relay Pin- D
[/B]
Old May 22, 2004 | 02:37 PM
Morley's Avatar
Dat it.
Old May 22, 2004 | 03:51 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
You Da Man Morley.
I should of been able to figure it out but with making fiberglass shifter plates, Dash Plates, ECM SWAP, ECT. there isn't much brain power left. lol or enough time in a day.
Old May 22, 2004 | 04:01 PM
Morley's Avatar
It can get confusing when the relays you get aren't pinned the same as the schematic you are using to wire it up. I had the same problem with my swap and ended up using a battery charger to actuate the relay and an ohm meter to verify which pins did what when it energized.
Old May 23, 2004 | 10:26 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Now Morley When I yanked these relays they came from a 90+ car that didn't have MAF and On the Relay Harness Plugs There are some 16ga or 18ga wires and then there are a couple 14ga wires.
My questions.
1. What pins on the Maf Burn Off Relay need to be heavier Guage
2. What pins on the Maf Pwr Relay need to be a heavier Gauge.
Since I have not wired the every thing up yet I can place the Thicker Guage Wires where they need to be. Better Safe than Sorry.
Old May 23, 2004 | 11:05 PM
Morley's Avatar
My questions.
On both relays the heavier guage wire goes to the coil. Pins D&F on the MR 44 and B&C on the other relay.
Old May 23, 2004 | 11:34 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Hmm Thats Odd. One of the MR44 Relays from the 90+ camaro I pulled is the fan Relay and it has the
Red 12ga on Pin-E
Black Wire with Red Stripe 12ga on Pin-A
But if my thinking is correct the wire comming off of the 85 Mas Module is 16-18ga so as long as all my wires are at least 16-18ga I shouldn't have to worry. Would you agree Morley
EDIT:5/25
Ok Morley I need your assistance again. I went out to my car armed with a jewelers screw driver and was going to attemped to repin my harness to beable to use the 165.
i Insert the jewlers screwdriver into One the upper hole of the harness. (there are 4 rows the 2 middle ones are what the ecm connects to the upper and lower one are where the relese clips are. I think)and i get the first wire to relese and slide almost all the way out of the connector and it catches something again. I tried to get it to come out more but I don't want to damage something so I figured I would Ask.
Old May 25, 2004 | 02:12 AM
Morley's Avatar
Red 12ga on Pin-E
EDIT:5/25
Sorry, I got the wiring wrong, the coils use the light guage wires, the others are the heavy guage, the coil takes little ampreage to operate and the actual circuit is the heavy amp draw.
The wires in the plugs will act like they are sticking just before they come all the way out. If the wire moved more with the screwdriver holding the lock than it does without, then you did indeed unlock the pin. It will take just a little more force to get it out all the way than it did to get it started out (if that makes sense)
Old May 25, 2004 | 07:57 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
Hey, just in case it wasn't clear anywhere(I didn't see it in this thread), the connectors also have a retainer 'comb' looking thing in the back, that helps prevent the pins from falling out, if the tabs would ever fail, so if you are encountering the pins getting stuck, if you didn't take the retainers off, they won't come out. You need to un-clip the small tabs on the corners and the retainers should come right out of the back. Kind of hard to explain, but hopefully, you'll see what I mean, they are usually different color than the connector body(yellow and blue come to mind). Just remember to label the wires, it'll take hours longer to trace them out if you don't. Good Luck!
Old May 25, 2004 | 10:32 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
yes the retaining comb is off. The wire is like 90 percent out of the connectorthe area where the connector has a strain relief that crimps around the wire is out side off the connector.
Update:5/25 4:37 P.M
I got the wire out that I was Experimenting with but now I can't get it to lock back in. I might of messed the connector that mounts to the wire up, but dosent look like it.
If so is there anywhere to order these connectors.
Update:5/25 5:57 P.M.
I Got the wire to lock in Just before I messed up the The locking tap on the Crimp Connector. I am just going to go to a junk yard and unpinn this wire from a connector and Splice it on the the wire in my car. But at least I figured out how to lock and unlock the tab.
Old May 25, 2004 | 04:37 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok Morley I think we need to re discuss the relay wiring .
Code:
Splicing     Using NEW STYLE RELAY
New hookup
if you do it this way the Maf Pwr Relay New Pin-D goes to D3 Ground & MAS Connector Pin-D
Where in the old relay configuriation Pin B which is the new Pin-D Goes to D3 Ground and There is no other connection. the MAS connection is taken Care of through Maf Power Pin-D
Code:
Splicing Using Old STYLE RELAYS
New hookup
See in the old code Which is in blue there are 5 seperate MAF PWR connections in the new Relay diagram you gave me there are only 4
Old May 26, 2004 | 02:18 AM
Morley's Avatar
Don't forget pin D 12 goes to pin B on the MAF burn off.
No matter which relays you use you still have the same number of connections, the only thing that changes are the relay pin letters, still the same number of them just lettered differently.
Old May 26, 2004 | 04:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
See if this diagram will help any with the wiring.
Old May 26, 2004 | 07:54 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Ok update:
Repinning the stock harness is now DONE Start to finish took me about a Hour and a Half. Have yet to Mess with relays. My brain Hurts lol
I think I am probally going to go to a junk yard and get the old 86-89 stlye relay, the one that mike davis uses in his tech article. So all I have to do is wire it according to his directions. The MR44 Relay using diferent letters and Pin configurations is also making my brian Hurt. ( I can't belive that 5 wires in a different configuration is so hard to figure out but that is the way it sems.)
More to come later.
BTW Trickster the diagram helps but the new style relays a confusing me as to what pin coberates with the old style relays pins. Thanks.
Old May 26, 2004 | 08:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello MTPFI-MAF,
Those relays that you have pictured are the same ones that I have in my car and are the ones depicted in that diagram. The MR44 will be for the MAF Power & MAF Burn-off. The rectangular one on the left (MR82) would be the fuel pump relay.
Old Jun 21, 2004 | 09:13 PM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
Splicing
I think I get every thing but this. Sry Could someone explain it another way?
Thank you.
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
