burning my own chips
Old Jun 6, 2004 | 11:25 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I would like to begin buying the proper tools to burn chips and was wondering if some of these items will do and what else will I need? I have an 85Z28 with speed density system. I am looking to purchase the following:
The moates adapter with 2 flash chips, the pocket programmer and software, and the code to unlock tunercat. I would have to download there demo.
A member here is selling this stuff for 250.Will I need to get either a datalogging program or scanner to monitor the changes I make? Which scanner do i need? I had a custom chip burned for me and I dont think its quite right. I also have heard that burning for speed density can be difficult. Thanks for your help.
Old Jun 7, 2004 | 08:05 AM
SBNova's Avatar
First, read everything at the top of this section that says "important/usefull" it answers your questions.
Second, your 85 isnt speed density unless it has a different computer(ECM). It should be a MAF car. You will need to know this as the ECU for an 85 is different than one for any speed density ECM.
Old Jun 7, 2004 | 03:07 PM
Its speed density...I switched it out.
Old Jun 7, 2004 | 06:57 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
You can do it cheaper. Read my post here (16th down):
https://www.thirdgen.org/techbb2/sho...hreadid=238523
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
