Warm-up enrichment (choke)
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
I have looked through the hac/code and searched the forum but can't find the tables for the warm-up enrichment (choke) amount and decay rate in the $8d code. The problem I'm having is I'm not getting enough fuel during the first 30 seconds of a cold (80degree F) start when first fired in the morning. It runs at 15 to 15.5 afr during that time then settles off around 14.6 before going into closed loop at 130 degree F.
Car: An Ol Buick
Engine: Vsick
Re: Warm-up enrichment (choke)
No warranty expressed or implied.
; START UP ENRICH vs COOLANT TEMP
; *** CHOKE ***
; TBL = 2.56 * %CHG
; %CHG Deg c
8431 F3 L8431: FCB 243 ; 94.9 -40.0
8432 C0 FCB 192 ; 75.0 -28.0
8433 9A FCB 154 ; 60.2 -16.0
8434 9A FCB 154 ; 60.2 -4.0
8435 80 FCB 128 ; 50.0 8.0
8436 40 FCB 64 ; 25.0 20.0
8437 40 FCB 64 ; 25.0 32.0
8438 40 FCB 64 ; 25.0 44.0
8439 31 FCB 49 ; 19.1 56.0
843A 26 FCB 38 ; 14.8 68.0
843B 26 FCB 38 ; 14.8 80.0
843C 0D FCB 13 ; 5.1 92.0
843D 0D FCB 13 ; 5.1 104.0
843E 0D FCB 13 ; 5.1 116.0
; FCB 2 ; 0.8 128.0
; FCB 0 ; 0.0 140.0
; START UP ENRICHMENT DECAY DELAY vs COOLANT
843F FDB 0512 ; MULTIPLIER for START UP
; ENRICHMENT DECAY TABLE
; INJECT Deg c
8441 FCB 0 ; 0 -40
8442 00 FCB 0 ; 0 -28
8443 19 FCB 25 ; 25 -16
8444 19 FCB 25 ; 25 -4
8445 19 FCB 25 ; 25 8
8446 19 FCB 25 ; 25 20
8447 19 FCB 25 ; 25 32
8448 32 FCB 50 ; 50 44
8449 32 FCB 50 ; 50 56
844A 32 FCB 50 ; 50 68
844B 32 FCB 50 ; 50 80
844C 32 FCB 50 ; 50 92
844D 32 FCB 50 ; 50 104
844E 32 FCB 50 ; 50 116
;START UP ENRICHMENT DECAY DECAY AMOUNT vs COOLANT
; TBL = 6.5536 * %CHG
; %CHG Deg c
844F FCB 255 ; 38.9 -40
8450 E5 FCB 229 ; 34.9 -28
8451 52 FCB 82 ; 12.5 -16
8452 52 FCB 82 ; 12.5 -4
8453 42 FCB 66 ; 10.1 8
8454 76 FCB 118 ; 18.0 20
8455 76 FCB 118 ; 18.0 32
8456 42 FCB 66 ; 10.1 44
8457 42 FCB 66 ; 10.1 56
8458 42 FCB 66 ; 10.1 68
8459 42 FCB 66 ; 10.1 80
845A A4 FCB 164 ; 25.0 92
845B A4 FCB 164 ; 25.0 104
845C A4 FCB 164 ; 25.0 116
; OPEN LOOP AIR/FUEL PCT CHANGE vs COOLANT
; TBL = (PCT CHG * 2.56) * (SCALAR/256)
L845D: FCB 221
; 0.863 SCALAR MULTPLIER
; ARG = 256 - VALUE, (35d)
; %CHG Deg c
845E F2 L845E: FCB 242 ; 94.5 -40
845F 99 FCB 153 ; 59.8 -28
8460 4C FCB 76 ; 29.7 -16
8461 32 FCB 50 ; 19.5 -4
8462 26 FCB 38 ; 14.8 8
8463 19 FCB 25 ; 9.8 20
8464 19 FCB 25 ; 9.8 32
8465 19 FCB 25 ; 9.8 44
8466 19 FCB 25 ; 9.8 56
8467 19 FCB 25 ; 9.8 68
8468 19 FCB 25 ; 9.8 80
8469 19 FCB 25 ; 9.8 92
846A 19 FCB 25 ; 9.8 104
846B 19 FCB 25 ; 9.8 116
846C 19 FCB 25 ; 9.8 128
846D 19 FCB 25 ; 9.8 140
846E 19 FCB 25 ; 9.8 152
That would be it.
MikkoV
Sep 9, 2015 04:25 PM
