what will happen if.....
Old Jun 30, 2004 | 04:15 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
what will happen if you put 24 lb/hr injectors in a car with an prom setting of 19 lb/hr? will it run rich? will it run at all?
Old Jun 30, 2004 | 04:31 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
It will run. It will run rich (the ECM will correct for this), but it will run fine.
I ran 24 lb'ers with my stock 19lb PROM for about 8 months with no problems other than low BLMs.
In fact, a little "Mangus" trivia - this is the exact reason I got into PROM burning... I needed to change the injector constant. What did I get myself into?!
Old Jun 30, 2004 | 09:17 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I think you've progressed a bit from just changing the injector constant! Actually, I bet you haven't spent all that much time actually tuning, seeing how much you've done with TunerPro!
Thanks!!!
Old Jul 1, 2004 | 12:03 AM
1992rs/ss's Avatar
so what would happen if I set the injector constant to 24lb/hr at which would be about 40 or so psi? I know it is only a 305 and that it doesn't need this big of an injector right now but later down the line when I go to a 383 it will need it, just didn't want to buy injectors twice. will the computer pull out some fuel if it knows they are bigger injectors and make it run less rich?
Old Jul 1, 2004 | 02:40 AM
Mangus's Avatar
Transmission: T5WC
get a scanner and answer the question for yourself. =)
Short answer is it will run fine.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
