Injector Driver
Old Jul 10, 2004 | 08:20 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Injector Driver
What are signs/symptoms of failing injector driver(s)?
TBI, specifically.
Old Jul 10, 2004 | 09:49 AM
Brent's Avatar
Here's one:
Problem
Solution
Old Jul 10, 2004 | 10:14 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I have one of those as my test bench ecm. Flashes the lights like its working properly but fails to be able to drive actual injectors at times. I wonder what causes the driver transisters to go bad in the first place?
Old Jul 10, 2004 | 10:54 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Heat.
The lower duty cycles don't seem to hurt them. But load, will. First they get a lil erratic, and then fail open. In my experiences.
Some saturated injectors internally short out (at varing levels), and can overload/heat the drivers. If they *short* totally and quickly the ecm isn't run long enough to ruin the injectors. It's the slow failing injectors that kill them.
The 2.8 and 3.1s with the 730 usually get a full no start when the injector resistances drop to low. So replacing the injectors is the healing solution (we typically).
A good way to see it and kill a 749 is running 8 P+H injectors instead of 6. Low DCs not problem, 4K RPM for a few minutes, and you can feel the ecm get hot, and eventually they'll start sounding erratic, and then quit. I've had that same routine happen 3x when testing 749s.
Old Jul 11, 2004 | 12:42 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Originally posted by Grumpy
Heat.
Well, I guess overheating would certainly do it.
69 Six Pack
Oct 5, 2015 07:51 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Bryan F
Aug 18, 2015 02:28 PM
kyleb24
Aug 15, 2015 08:24 AM
