7747 Cool Compensation Spark Table
Old Jul 11, 2004 | 02:52 AM
ben73's Avatar
Guys,
This 3d table is displayed in TC as being 5-115degC x 0-40kPa MAP.
What happens from 40-100kPa?
I'm guessing that it uses the values in the 40 MAP column at 40-100kPa MAP.
Can anyone confirm this for me?
I've burned few different eproms to experiment with this, and it looks to be the case, but its difficult to do repeat testing because it the coolant heats up too fast to get many tests in! ;-)
Old Jul 11, 2004 | 06:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 7747 Cool Compensation Spark Table
Originally posted by ben73
Guys,
The columns are 40 to 0 KPa of vacuum, not pressure. If barometric were 100 KPa then the table is from 60 KPA to 100 KPa of MAP.
RBob.
Old Jul 11, 2004 | 06:41 AM
ben73's Avatar
ahhhhhhh, now it makes sense! Thanks!
I have changed my .ecu file to reflect this.
I thought that all references to Manifold Pressure were measured in Kpa absolute, thats why we call it m'A'p.. ;-)
There's always an exception to the rule huh!
So when the pressure moves beyond the boundaries of the table, does it just use the values in that 1st column (40kPa vac / 60 kpaA) ??
Old Jul 11, 2004 | 07:22 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
With an ecm bench that'd have been a 3 min., ordeal to figure out.
db057
Jan 10, 2020 08:55 PM
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
RedLeader289
Sep 23, 2015 06:50 AM
ULTM8Z
Sep 16, 2015 09:15 AM
