adding a 0-100 kpa to the $60??
Old Jul 15, 2004 | 08:28 AM
FireBird88's Avatar
i was reading some stuff for the 7749, and was thinking
since we have the code for $60(thanks grumpy), why not make it more like the $8D for none boost areas. <~96 kpa.
0 - ?(96 or 100) kpa VE table maybe
i would but w/ school and learning the asm for the 60 code. it would take years for me
Old Jul 15, 2004 | 11:24 AM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
The 7749 code only uses the 2 bar MAP for the following tables:
Main Spark,
Premium Fuel Spark,
Boost Multiplier for Fuel,
Cold Engine A/F Ratio
When the 2 bar option isn't selected, the 1 bar MAP is used instead. I haven't confirmed this personally. But, I believe the resolution of these tables is "doubled" when using the 1 bar sensor. So, instead of a MAP axis of 0, 10, 20, 30... you'll get an axis of 0, 5, 10, 15, 20, 25, 30...
So, if I read your post correctly, the ECM already does what you want it to do....?
Ed1LE
Sep 30, 2018 09:14 AM
86IROC112
Nov 7, 2015 06:50 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
