What VSS for 1990-92 '730 ECM?
Old Jul 30, 2004 | 04:26 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
I understand that it's a 4-pulse VSS. What type of sending unit does it use? Is it a Hall-effect unit or a Reed type sending unit?
Any other pointers?
Old Jul 30, 2004 | 05:15 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The one I am using
I purchased an aftermarket one that (I think) was the same as an old OEM unit. www.jagsthatrun.com (Stealth conversions)
The number was " 4PAC INTEGRAL" it has a cable drive and the 4 pulse per rev. magnetic pulse generator. I needed to keep the cable drive intact for my speedo.
It was about $90 from memory but is working good.
The mating connector was Delco PT-120, or GM #12085498.
They also helped me out with the selection of the drive gears to get everything to about 1% error. (or at least that what it should be).
Hope that helps.
Edit: to answer that question, I'm pretty sure this one is a reed type.
Old Jul 30, 2004 | 05:58 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Heres the one I used.
http://store.summitracing.com/partde...6&N=120 308231
Old Jul 30, 2004 | 06:36 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: What VSS for 1990-92 '730 ECM?
Any other pointers?
It is an A/C generator. Has a coil of wire where the ends are the signal leads. A magnet rotates within the coil.
RBob.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Jlanz55
Sep 29, 2015 08:55 AM
