AE surging in low RPMs
Old Aug 3, 2004 | 06:13 PM
nhromyak's Avatar
Car: '73 Chevy Blazer
Engine: BBC - 408
Transmission: SM465
I tried giving it more fuel and less fuel with AE Delta Map, and AE Delta TPS vs. TPS.
I have also tried changing the % Decel fuel (I forgot the table - it's the slope to turn off AE). As I change this, I lose post acceleration, so I don't THINK this could be it.
Anyhow, always in the lower RPM (800 - 2000), I get a pulsing kind of accerlation. Then after 2000 it's all good. I am leaning towards my VEs as being off, but they appear to be good (around 125 - 130).
Perhaps I have my delta MAP too far, and my Delta TPS vs. TPS not far enough?
Thanks.
Old Aug 3, 2004 | 10:44 PM
funstick's Avatar
are yo working with $8d code. If so there is a MAP AE scaller value in the constants. you might want to play with it and the TPS AE scaller as well. sometimes i find that engines go into Ae to late or to soon based on load changes. give that a shot and mae sure to note your starting setings.
Old Aug 4, 2004 | 01:04 PM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
Sorry, $8D
I played with the AE Map scaler and (as I recall) I went too lean and too rich before when I tried one or two 100ths points changes. This was before I changed the TPS and MAP deltas.
I will look at it and try again though. This will mean I have to change the Delta TPS and Delta Maps to compensate... correct?
Thanks.
jklein337
Sep 19, 2018 06:23 PM
bamaboy0323
Sep 3, 2015 06:07 AM
jbd1969
Aug 17, 2015 07:06 PM
Jake_92RS
Aug 17, 2015 09:42 AM
