Help me analyze BLMs
Old 08-12-2004, 10:00 PM
Mastiff's Avatar
I was going to just try and tune this away with the VE table, but thought I'd ask first. Do you think this large variation in BLM indicates a problem? Specifically, the 159's at low idle. Does it look like it could be related to an exhaust leak drawing air to the O2 sensor at idle?
Thanks for any advice.
Old 08-12-2004, 10:27 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
What mods have you done to your car? What kinda car is it? It could be a normal untuned car or it could be a problem it just depends on what you've done to the car.
Old 08-12-2004, 10:37 PM
Mastiff's Avatar
The VE table is factory stock. It's for a mild 350 with Edelbrock performer intake, headers, no knock, and no emissions (no EGR). No other mods I can think of except open element air cleaner, if that matters.
The reason I have no good baseline is because I'm converting from a carb. I bolted everything on, and this is what I'm getting. I wouldn't expect such a discrepancy from a factory 350. The headers and open air cleaner might raise the VE across the board (?), but it seems odd that it's really lean at idle and not so bad at higher RPMs.
Mark_ZZ3
05-24-2018 01:02 PM
antman89iroc
36
01-31-2016 08:42 AM
89fast5oh
09-27-2015 09:04 PM
ULTM8Z
09-16-2015 09:15 AM
CORV3TT3
08-23-2015 11:26 AM
Quick Reply: Help me analyze BLMs
