more newb questions.. 94lt1
Old Aug 15, 2004 | 07:57 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
would a 96pcm work with a 94pcm? IE can i use a 96 pcm and load a 94lt1 bin into it? I just happen to have a spare 96lt1 pcm..
also.. what is the diff from a std trans. pcm and an auto? I have pcm from auto but am driving a std. (T5)
thanks again.
Old Aug 15, 2004 | 08:12 PM
11sORbust's Avatar
You have the wrong msg board. LT1 edit has support forums. you'll have better luck there. Or the ls1/lt1 tech forum
Old Aug 15, 2004 | 08:33 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
im using tunercat.. is there any support for lt1 wit that?
Old Aug 15, 2004 | 08:46 PM
11sORbust's Avatar
I don't think so. Might want to email them. I don't think anyone here has tuned an lt1....
Old Aug 15, 2004 | 09:10 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: more newb questions.. 94lt1
96 is OBDII, for the moment the only tuner I know of is like $1K for them.
The 95 is flashable, I don't know if the 94 is a memcal or flash.
Old Aug 15, 2004 | 10:48 PM
funstick's Avatar
ok
94-97 all flash. there are some pin location changes. 96-97 isd obd2. 94-95 is obd1 with obd2 connector.
ive done lots of tunning with lt1 pcms. what exactly are you attempting to do. i can offer some help for sure.
Old Aug 16, 2004 | 04:13 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
i don't understand the tables is the big problem.. i don't understand how MAP is relitive to RPM .. and how it works with spark advance..
basicly want to advance timing if i can and get fuel under control.. think it is way too rich at WOT.
basicly trying to add power.. but don't understand the fundementals.
my question on the pcm it self was whether i could reprogram the 96pcm to be = to the 94.. ie obd1.. just so i'd have a replacement.. I got it for $25cdn and since they're out of 94-95pcms it would cost over $150 to get one..
Thirim
Aug 16, 2004 01:08 PM
Thirim
May 6, 2004 07:57 AM
Goofy
Mar 5, 2003 12:05 AM
Meyaht
Jul 13, 2002 11:48 PM
okfoz
Jun 13, 2001 10:44 PM
