LT1 Swap Timeslips?
Old Feb 28, 2003 | 04:46 PM
Goofy's Avatar
LT1 Swap Timeslips?
Looking to see what you guys are running for times, mainly close to stock engines, what i have is below:
94LT1
Hooker Shorties
Flowmaster (full length)
TPIS stage 3 programming.
K&N Directly onto MAF
1le intake elbow
Bosch Plat. +4's
posi 3.23
Old Mar 1, 2003 | 09:01 AM
LT1swapper's Avatar
Good question, I am a little curious what my combo might run. Anyone want to take a wild guess? I am thinking high 13's
With any luck I can find out for myself in a couple of months.
89 Formula hardtop
Tremec 5 speed
96 LT1 (completely stock)
SLP 1-3/4" headers with dual Random Tech Cats
SLP TOTL cat back
3.45 Posi Rear
Spohn Torque Arm, LCA's, LCA Relocation Brackets, SFC's
8 Point S&W cage
Old Mar 3, 2003 | 08:51 PM
1QckSC's Avatar
It would depend alot on tire and track conditions...ie: temperature, elevation etc., but I would guess somewhere in the mid 14's with street tires and decent conditions. With DR's you could pull off high 13's with a good launch. I don't know if that helped any, but there you go.
Old Mar 3, 2003 | 09:46 PM
HybridZ28's Avatar
They asked what a LT1 swap car would run .. Not a stock L98 car. :-D
Old Mar 4, 2003 | 12:34 AM
1QckSC's Avatar
I was talking about an LT1, my estimate may be low, I'm from Vegas and the track is at about 2,700 feet and the temperature gets up around 110*. If you're at sea level and it's cooler, obviously you'll run better numbers.
PS: Where are you finding stock L98's that run high 13's to mid 14's?
Old Mar 4, 2003 | 12:35 AM
1QckSC's Avatar
I meant to say my estimates may be high, sorry about that.
Old Mar 4, 2003 | 08:25 AM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
I'd guess mid 13s. I have a buddy that ran a 13.28 with his 93z completly stock with an auto and 3.23s. With your headers and suspension work you might break into the 12s. His was completly stock. It amazed me.
Old Mar 4, 2003 | 08:32 AM
TexasLT1's Avatar
Car: '92 RS
Well, I've run a best of 13.1 at 108 with pretty much a Hotcamed LT4. I'm guessing I'm close to 400 hp with a stock T-5 and 3.42 gears out back, on Goodyear Eagle tires. Only suspension mods are Spohn LCA brackets and Hotchkis lowering springs.
Old Mar 4, 2003 | 09:53 AM
Goofy's Avatar
The 3rd gens run a little lighter than 4th gens, dont they?
Using some kinda weight thing online, it showd my car about 3250. I think 4th gens run around 3400?
Also, would 3.73's be a good improvement over my 3.23's?
Old Mar 4, 2003 | 12:56 PM
mat89RS's Avatar
You should run mid 13.
Old Mar 4, 2003 | 11:09 PM
Goofy's Avatar
What are some good ways to lose weight while leaving the front/rear seats in.
Old Mar 5, 2003 | 12:05 AM
1QckSC's Avatar
First, you could start by removing sound deadening insulation. Other than that, you could temporarily remove the bumper supports at the track or if you are going out to race, but I would only do that if you really need it.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
