CCP when output energized flag
Old Aug 24, 2004 | 08:38 AM
conv90's Avatar
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
please see this
https://www.thirdgen.org/techbb2/sho...hreadid=166985
basically this tread says:
JAY87GTA:--I have a BLM cell always to 4
--the Tim anwere is : "Did you disable your charcoal canister purge in the PROM? If you disable the CCP using the flag then you will always be in idle cell #4 unless you change the Duty Cycle % threshold which forces cell #4. "
JAY87GTA:
"Yes I disabled the CCP. "
A stock AUJUP has this flag unchecked ( )
To disable the CCP "using the flag" means that the flag must be checked? (v).
In addition I read all the super AUJUP tread and I downloaded the bin.
The .log file of this superAUJUP bin say:
Canister Purge when output energized flag UNCHECKED.
I downloaded a stock AUJUP and this Flag is UNCHECKED ( ) too!
Could someone explain me better this flag? (CCP when output energized flag)
I'm asking this because in my ANHT I've this flag unchecked ( ) and I don't know if I have to lower to 0 the constant "Force BLM idle Cell CCP % Duty Cycle Threshold" in order to combat a BL Cell of 4
-Beppe-
Old Aug 24, 2004 | 09:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: CCP when output energized flag
Originally posted by conv90
. . .Could someone explain me better this flag? (CCP when output energized flag). . .
-Beppe-
That flag is used to invert the polarity for activating the CCP solenoid. IOW a low voltage activates the solenoid or a high voltage activates the solenoid.
You do need to change the force idle cell if CCP parameters.
RBob.
Old Aug 24, 2004 | 10:26 AM
conv90's Avatar
Car: superrammed V
To make the story short:
What I don't understand is:
... He checked (v)
or unchecked ( ) the flag??
-Beppe-
Old Aug 24, 2004 | 11:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
... He checked (v)
-Beppe-
Checking or unchecking that flag will not enable nor disable the CCP. Note that later in that thread it is stated to set the purge% to 0. Here:
Code:
L8522:	FCB	69 	; FORCE   IDLE CELL LRN IF CCP DC LT 69
RBob.
InfernalVortex
Apr 20, 2021 11:31 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
