EGR, ARAP 6e and code 32..disabling??
Old Aug 26, 2004 | 05:56 PM
sparks454's Avatar
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
just upgraded from the 32b bin to the ARAP 6e using my 165ecm. Now when the car is started cold it throws the 32 code. I am using TunerproRT and have the EGR Disable temp set to .5 degrees or less and still show the error. If i use winbin and the 6ev009.ecu file to open my 6e arap bin, it shows the egr checked off. When I use tunerpro, the only selection that coincides to that bit (bit 3 in the VSS/egr diag. table) is the 4th airflow mode table where bit3 is checked and shows CCpin at that spot. I don't know what CCpin is....any ideas??????
Is the EGR bit selected/not selected in the stock ARAP bin and is this bit known as CCpin(bit 3) in the 4th airflow mode table.???
If not, Where in the airflow mode tables #1-4 is the bit to turn off EGR diagnostics????
Thanks,
Chris
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
pacoelrapido
Sep 11, 2015 02:41 PM
mdtoren
Aug 23, 2015 12:52 PM
