car will not start
Old Aug 27, 2004 | 04:36 PM
smokeingGTA's Avatar
Car: 89 firebird GTA
Engine: 350 T.P.I
Transmission: 700-r4
car will not start
ok I just bruned my first chip, just put a arap bin on it and went on a test drive. I stoped and got some gas and when it started it reved up to about 2000rpm for a few secs and went back down to where it should be. I packed it for a day and now it will not even crank. I tried rebruning the bin and and truned off the vats and still nothing. I tried to check for codes and that does not work. I have no idea of what happened. I have a 89 gta 350 tpi with the moates adater and a at29c256 chip. It had to be setup up right to start the first time and I did not change anything but now it don't even crank.
Old Aug 27, 2004 | 09:00 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
crank as in starter turning or do you mean as in firing? have to ask because alot of people call a cranking starter "no crank"
Old Aug 27, 2004 | 09:13 PM
Engine: 350 T.P.I
I found out the adater came undone I pulled it out and put it back in and it works. It always is the easyest things.thanks anyway
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
