what dose it take to make a spark only bin
Old Sep 2, 2004 | 08:38 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i need to figure out how i can run a carb on my truck for a few months it has a 747 ecm. i would like to keep the stock dizzy and just throw the carb on as a temp till stuff comes together. thanks ahead of times guys
Old Sep 3, 2004 | 05:15 AM
Z69's Avatar
Z69
There is a file called 7747sprk.txt on DIY-efi.org.
Not much needs done other than turning off some DTC's.
And making a TPS bracket for your carb....
Unless you make a cable op thingie like S&P or somebody sells.
A manual choke holley looks to be reasonably easy. Just make a mount plate to go on the manual lever plate and a rod to screw into the primary throttle shaft with a flat on the other end to turn the tps. I'll be doing one in a month or two.
Old Sep 3, 2004 | 06:07 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You sure, about the TPS?.
As I recall, it's not needed.
Old Sep 3, 2004 | 07:26 AM
Z69's Avatar
Z69
Correct, not required IIRC from the txt file or somewhere.
Maybe it was one of your posts.
But nice to have, and I have 8D stuck in my head.
I don't recall how PE is done in 747 land.
Old Sep 3, 2004 | 08:31 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Ooops, I forgot some people use a PE spark adder.
Old Sep 3, 2004 | 09:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With a carb it is better to put any PE type spark in the main SA table. In this manner it can be setup to coincide with the power valve or step up rods activating (via manifold pressure).
RBob.
Old Sep 3, 2004 | 04:38 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I used Rbobs spark only tutorial for quite a while on my car while I got the hang of this chip tuning thing. It's quite easy. Just follow his article and it will tell you what dtc to turn off and what other parameters to play with. The tps is not needed, unless your wanting to use the TCC lock up, there is a flag that makes it MPH based but I never played with it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
beast94
Aug 20, 2015 06:44 AM
ezobens
Aug 19, 2015 10:29 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
