final spark advancer
Car: Vibe, 99 TransAm Conv, pickup
Engine: stock
Transmission: ZF 6 speed
How do the various tables and constants that affect spark advance interact? The main tables/constants I am aware of are: initial spark advance, warm and cold spark bias, main spark table, and coolant compensation spark. From what I read, the formula for the advance as seen by the engine should be initial advance - bias + main + coolant comp. I don't think that can be right because it gives way too much advance based on the .bin file that I have developed vs factory recommended spark advance. Could the coolant compensation be some kind of multiplier rather than an adder?
Along the same lines, is there a constant someplace that defines where you switch from cold spark bias to warm spark bias?
I'm pretty new at this. Hope these questions aren't too stupid.
Thanks,
Druber
Thanks,
Druber
Car: check
Engine: check
Transmission: check
Polo Z03
Sep 10, 2015 06:43 PM
