Cold start spark advance question
Old Aug 31, 2015 | 06:55 PM
htrdbmr's Avatar
Car: BMW 735
Engine: 383 W/ SUPERAM
Axle/Gears: 3.64
I've screwed something up, now on start up my spark timing is barely enough to keep the motor running. When the coolant temp reaches 44.75C, the timing goes to where it belongs, and all is good. In the scalars, I see that Spark advance cold disable is 44.75C, as is Spark advance hot disable(44.75C) What should these values be, and what is meant by these parameters?
Old Aug 31, 2015 | 07:28 PM
htrdbmr's Avatar
Car: BMW 735
Axle/Gears: 3.64
Re: Cold start spark advance question
I found it (730 cold spark advance from guide book and FAQ) I had imported a new main SA table, and the 400,600, and 800 rpm @ 100 kpa was 6 degrees. Mine needs 25 deg in those cells.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
