730 & Low-Z Injectors?
Old Sep 10, 2004 | 08:39 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Can the 730 ECM be modified like the 749 to run eight low-z injectors? From my understanding, these ECM's are virtually identical (functionally), but heard this is not possible. Is the internal construction so different that it's physically more difficult to replace the sense resistors and transistors in a 730?
Old Sep 10, 2004 | 08:46 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
No...... 730 only has 1 driver, 749 two.....
/N.
Old Sep 10, 2004 | 08:47 AM
Willie's Avatar
Does that mean too much current thru one driver?
Willie
Old Sep 10, 2004 | 08:52 AM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
if you are real ambitious, you could get parts from a spare 730, and put in the transistor and chip and other parts into your good 730 board to make it similar to a 749. You could also change current sense resistors to handle the current too, I think.
Old Sep 10, 2004 | 08:53 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Probably yes, it could also be a problem on the 749 with to much current througt the board, so its best to add a jumper from the driver to a xtra pin......
/N.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
