blm stuck on 114 at idle?
Old Sep 15, 2004 | 03:00 PM
Markgyver's Avatar
Car: 1992 K15 Blazer
Engine: 383 with TPI, Edelbrock Intake & Runners, 24lb svo injectors, 730, $8d
383, TPI, SD, 7730 ecm.
Im have been working on my VE tables and have noticed that no matter what I do it seems that my BLMs are stuck on 114 at idle.
Old Sep 15, 2004 | 03:36 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
What .ecu are you using? Are you tuning the VE lower table in the 600-1000 range at 30-45 kPa? Are you waiting for closed loop to turn on? Is learning activating? Are other cells changing? What happens if you reset your ecu (disconnect the battery)?
Old Sep 15, 2004 | 03:56 PM
Markgyver's Avatar
I am using Super-8dm2.ecu
Yes I am tunning in that range. The Closed Loop is on and the Learn control is Enabled. The other cells are changing. I have not tried reseting the ecm...
Also how long does it take the ECM to learn a new chip?
Old Sep 15, 2004 | 05:11 PM
How drastically are you changing those points? I've seen some pretty steep VE changes around idle to get BLFs up - like a difference of 10 from the cells around it sounds familiar at least when dealing with non-stock setups and roughed-in tuning.
Once learning activates, it should start immediately incorporating the Integrator into the block learn.
Old Sep 16, 2004 | 03:34 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I had similar problem on one car, check the BPW while your scanning if they drop and BLM is the same, bad O2 or bad injector.
(my case 2 inj. was bad...)
/N.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
corey8084
Sep 17, 2015 02:56 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
IROCtometal
Sep 9, 2015 10:01 AM
